Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Why do I hear lots of bad things about the Discovery series 2?
    Speaking to a few people who know rovers quite well, it seems that there is a real trend saying that the series 2 disco's are prone to maintainance issues.
    Just wanting to know from those who have the D2's.
    Is the injection system that bad on the 4lt V8 that it makes fitting LPG a real nightmare?
    Are the d2's any more prone to problems than a late series 1 disco?
    Just wondering as I am seriously in the market for a Disco, just trying to find the right one.
    Which type of Disco would YOU buy to get true value for money and why?
    Choices would be either 97-98 S1 in TDi 300 or V8 on gas. Or a 99-00 S2 in TD5 or V8 on gas.
    Any advice would be greatfully accepted, as I am still scratchin my head thinking about this issue.
    Thanks, Wello
    Kyabram, VIC 3620
    Quote Originally Posted by Wello View Post
    Thanks, Wello
    I have a 2002 DII, not really had any problems since buying it - apart from a new battery. Plus hitting a few tree stumps off road. Otherwise great.
    Don't get an 2001/ 2002 though as they don't have the CDL mechanism
    May 2002
    Sydney, Australia
    Get a late model 300 TDI Auto - upto 1999
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    DougLD Guest
    Hi Wello
    We have a 2002 TD5 update model I am happy with it the only problem that we have had with it is oil in the loom which is a moderately expensive repair $500 + there are a few other issues with the TD5 but they we haven't had them yet. I would still buy another one tomorrow if we had to replace this one. we have traveled around 110000 klms in it so far.
    Doug
    PS Older Rangies are great to
    Williams West Aust
    Hi Doug
    Hopefully you will have missed the plastic dowels in the head we have(mines fixed).But has yours got a CDL???? That must have been the tradeoff real dowels drop the CDL!!!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Adelaide Hills - SA
    I've got one of the late D1 TDi300's in a manual. Its' been a brilliant car. Simpler than a D2 but it hasn't got nearly so much boot space.
    In 9 years the only bad thing it's done is do a head gasket due to low coolant (welch plug problem - weeping and I ignored it). I've got a low coolant level alarm now for $200.
    Don't know anything about the V8s. I tried a few when I was buying mine, and there wasn't a whole lot in it and the fuel consumption on the Diesel is remarkable for such a heay car (10L/100Km or 28/30MPG consistently whether you drive it easy or hard).
    D1's are so cheap these days that I can't see myself ever getting rid of it. Good for you if you are purchasing, but bad for anyone selling.
    MarknDeb Guest
    Gday Wello we have a 03 D2 td5, the only thing we have had to get done is the brake pads & rotors replaced at 46000 k's. The car has been fantastic, it has real good economy. The main reason we got ours is we tow a 2t caravan and it does that well as well.
    Alstonville...is near Byron Bay
    The D2 is also the P38 RR with a few things missing, and its a great piece of work but -
    the V8 chucks down juice
    it generally doesn't have a CDL
    the diesel version has had some issues - like the famous 'loctite' saga, which if not sussed and fixed could cause the owner to forkout $17000 for a new donk etc
    but a goodie is a great piece of work (with a CDL)....
    my neighbour 200 metres away has a V8 (on road tyres?!?!?!) and it's sweet but it drinks more than any alcoholic....
    and 'bruiser', nearby, got a diesel some years ago when LR were doing deals - half upfront - the rest in two years - and that's never had an issue.....he reckons its the best ROver he's ever had (and he has ten, like Ps and Ds and an SD1 and stuff)
    NSW SW Slopes
    Hi Doug
    Andrew
    They still had plastic dowels on the early MY03 after the CDL was properly brought back. Mine's got plastics according to the VIN for when steel was introduced. But it seems that plastic is only a problem if the head loosens, as happens if it overheats.
    Thanks, Wello
    it like everything
    Someone who is happy tells hardly anyone, but somone who has a problem tells everyone they can
    There is a thing in retail which says if you give good service then they will tell 3 people but if somthing goes wrong they will tell about 30 people
    just human nature
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
