Thread: Am I a Gumby
    Kippa Ring
    Am I a Gumby
    Am trying to remove the CD Strombergs from my 81 RR. The manual makes it sound quite simple but to remove the lower nuts from the drivers side carby the only way I can see to get a spanner on is to remove the rocker cover to get a bit of purchase on the nut.
    Am I missing something?
    Avoca Beach
    Bend the spanner.
    I knew why I had that bent spanner in my tool box. I just forgot why.
    Regards Philip A
    Sunny Pucka
    I've got a few modded tools in the odds and sodds box, some bent, some slightly filed, some with welded extentions. Sometimes you need to get the job done,
    Kippa Ring
    Yep, know where you are coming from. This is my fourth landrover product so from past experience, unless I can get hold of special service tool xxcdg6668ffd then I suppose will have to dismantle rest of vehicle to rebuild carbies.
    Thanks for your input
    Gilderoy, Victoria
    Quote Originally Posted by jbarracl View Post
    You only need to take the wheels off to rebuild the carbies.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
