Results 1 to 10 of 15
Thread: I'm at a loss
    Oct 2003
    Gold Coast, Qld.
    I'm at a loss
    Okay as some know... i've been having problems with my disco.
    Originally i started getting a sort of miss while driving untill it finally died and wouldn't start again and was put down to the airflow meter... so i had it replaced... when i picked it up and drove for 40mins home was having the same missing feel to it so put it down to being overdue for a service so figured would get it done when back from holidays.
    A couple days later died again and worked out it was the fuel pump... a couple sharp knocks and it started again so had the pump replaced yesterday... tonight it stopped again and seems to be the pump again....
    SOOOOOOOOOOOOO... what next??? I assume can't be the pump if just been replaced... and worst of all... does that mean the airflow wasn't at fault again at 1700 for a replacement???
    I'm lost now Please Help Me
    RAAF Tactical 200184 & 200168
    Piggabeen (Tweed Heads)
    Problem
    Josh do you have constant 12V power to the pump????
    If so are you sucking rubbish into the pump???
    Did you check out the old pump before tossing it.???
    I assume your hitting the pump because its stalling or seizing???
    Just some ideas
    Justin
    what was in the fuel filter?
    your fuel pressure regulator may be sticking open..
    elec connection to the fuel pump... replacing the fuel pump wont fix it if its just getting an intermettant connection somewhere.
    how is the fuel filter and all the subsequent fuel lines?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    bloody useless v8's hey pedro :P
    ignition module been checked?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Oct 2003
    Gold Coast, Qld.
    Haven't checked anything else as yet and no haven't got the other pump as had a workshop do it for me but going to call them in the morning to see if they still have it.
    Will try to check the other things tomorrow... anything else?
    Williams West Aust
    Try pinching off the return line to the tank,will indicate if the fuel pressure reg is letting all the pressure back to the tank and not the injectors.
    The trusty multigrips got me home one night in our XE EFI Falcoon we once owned!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    SYDNEY -in the shire.....
    i had a similar problem on my ol'mans lexcen......the fuel pump died......
    i fitted a new pump and it almost pumped a full tank of fuel before it too died.....
    so...after removing the new pump to fit another new pump.....we noticed the power plug on the actual
    pump (in the tank) had loose connections and was arcing....it proceeded to burn out the terminals till they wouldnt make contact.....
    so....before fitting the second new pump.....replace the connector and made sure it had good contact......
    the thing is still running......many tanks later......
    so...try checking as many connections as you can and see if any are burnt.....
    another trick we used to do was.....run a wire from the fuel pump back to the dash and connect a small LED to it......
    if the car stopped and the LED was still lit.....it eliminated all the wiring up till the pump.....
    a fuel pump doesnt NORMALLY cut out whilst running.....it wont work after the engine has been switched off......
    so...you are driving...all is well.....then you switch off......and it wont start.....
    reading your first post again......it sounds like coincidence your pump packed it in when it did......
    it may be something else which is heat related......or affected by heat.....
    such as coil.....air/vacuum leak.......fuel pressure reg as mentioned above (very common).....ignition module....?
    there are many things it can be......the problem is its intermittent.....which means you simply guess at a common problem......
    replace that component...cross your fingers and see if plays up again......
    if it does play up again......you change another part......this is where dealerships benefit.....
    they have other cars they can BORROW parts from.......till they track down the problem.....or even transfer it to the other vehicle........
    connect also a fuel pressure guage along with the LED......it will tell you where to start looking for the problem......
    Perth, Western Australia
    Does the disco have the fuel pump at the tank or up front?
    I had very similar problems with a vn commodore... went to replace the fuel pump (which is inside the fuel tank) and the bottom of the tank was full of sugar....
    The symptoms were: the car would run happily for about 20-30 mins and then buck under load or high road speed before cutting out completely. A 15 min rest and it would be ready to go again.
    Whilst its probably unlikely you've go the same deal, perhaps the bottom of your tank is full of water or other crud like DRanged suggested?
    up2nogood Guest
    Quote Originally Posted by Outlaw View Post
    Is that 1700 dollars for an airflow meter!? Holy sh*t.
