Results 1 to 6 of 6
Thread: exhaust Bypass valves NOT A DIESEL QUESTION
    I saw a doco on foxtel the other day, big pounding V8 muscle car type show, one an old yank tank (the Goat) pontiac GTO had an exhaust bypass valve fitted. Has anyone used them before?
    I presume you all would realise this would be for off the public road use only.
    mcrover Guest
    I have seen them on street rego'd drag cars before and they have been around since the 60's but they are not all that effective unless installed properly and then when the main exaust is in play it acts as a resrictor.
    Well thats the old ones any way.
    They are for lazy people who don't want to pull their exaust off and bolt a side pipe on at the drags or for people who don't care about EPA noise pollution levels.
    Either way I wouldn't bother, you need back pressure 4wding on petrol engined landrovers and you should have cut the mufflers out of you diesel landrover by now so what do you want one for.
    St Helena,Melbourne
    4.28 MB
    Used to be able to get them from performance wharehouse, they are a cast Y shape piece with a large butterfly that directed the exhaust to either the muffler or straight out to the side.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2003
    On The Road
    Quote Originally Posted by mcrover View Post
    back pressure is an urban legend.
    Avoca Beach
    Look in AUTOSPEED. There is a new type available that can be electronically controlled.
    BTW the New Aston Martin Vantage has one. If you saw Top gear the other night they were marvelling at how loud the thing was under full throttle.
    BMW E36 328i also had one in the rear muffler.
    In my experience you do not need backpressure. Even the high volume standard muffler on a 92 onwards Range Rover has very little backpressure at idle or low revs. I think this furphy comes from the fact that if you have restrictive mufflers it takes longer for water to go up exhausts if the engine stops in water.LOL.
    It is also true that tuned length extractors will give more power than just an open exhaust from a manifold, due to the scavenging effect of the exhaust gas from one cylinder rushing past the pipe from another cylinder. So to that extent, pipes are better than no pipes.
    If you designed a muffler to have significant backpressure at idle/low revs, the backpressure would increase enormously at high revs. it would be like having a potato in the exhaust!!! LOL
    Have a look at the series of articles in Autospeed that have been published over many years. Also there was a series/book on back pressure and exhaust design by LKJ Setright before he died.
    regards Philip A
    Avoca Beach
    Did some research for you
    Autospeed issue 123- Pure Pipe Perfection 2
    Autospeed issue 300- Butterfly effect
    I have no relationship or knowledge of this but contact is
    Kevin Davis
    Active exhaust systems
    0409 288 347
    kevindavis2exemail.com.au
    Regards Philip A
