I put in a o ring that had a thicker cross section and no more leaks from that area
I've discovered the source of an oil leak on my Td5. All it took was to remove the engine cover and see that the cam shaft end cap (black plastic bung + o-ring) was half out of the hole at the front of the engine and only held in by the wiring harness that passes in front of it. The damed thing clicked back into place but I would hardly call it secure.as it can still move around. I'll chase up a new O-ring tomorrow.
Is this at all common???
disco seriesII mods so far:-bullbar,hyd winch,
detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
In the event of nuclear war,Disregard this message
AS COMMON AS!!!!!
Mine was too!!!!
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Yay I haven't had this issue!
I have a spare one in the tool kit though as I ordered the wrong cap after loosing the rear one.
Oh crap, didn't think to look at the back one. The rear of the engine is clean though so it must still be in place. I guess I'll check it tomorrow and make sure both are OK.
The 4wd Zone/Opposite Lock Bathurst
263 Stewart Street, Bathurst, NSW
http://www.the4wdzone.com.au/
Discounts for AULRO members, just shoot me a PM before you purchase.
Hay there
I found my front seal / plate was loose this morning and so did the search on AULRO and am here.
Just been to the stealership and its near on $40 for the cover, but above it seems that an o-ring can be installed.
Can any one tell me the dimensions of the o-ring I need to get to replace the item there?
as for where the existing o-ring is.....i shall let you know.....
thanks
Hay Ewe
Try this thread for the sizes.
TD5 CAM PLUG FIX!
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
