Results 1 to 10 of 12
Thread: Series IIA engine problem
    Darwin NT
    G'Day all, I'm having trouble locating a problem with my 2.25ltr petrol engine. I am hoping that someone can identify the problem from the following symptoms...
    a) The vehicle is a 1968 ex-army LWB series IIA, all original 2.25ltr petrol engine.
    b) Engine starts first time every time, and idles beautifully and will rev freely when the engine is stationary.
    c) However when I take it for a drive it starts to spit and fart in the upper rev range??
    d) I have recently replaced all HT leads, points, dizzy cap, and rotor. I have also just re-kitted the carby (only non-original part on the vehicle - stromberg).
    It sort of feels like something is restricting the engine when I put my foot down. If I only press slightly on the loud pedal it will let me slowly accelerate, but if I put my foot down it starts to fart and backfire???
    Just not sure where to check...? Does it sound like a fuel problem or electrical?
    Hope someone can help explain, I have owned the vehicle for 18 years now and have been able to fix every other problem, but htis has me stumped!!!!
    thanks tim
    Darwin NT.
    Sounds like a fuel delivery problem, who rekitted the carbie and was it tuned to the vehicle. Or opposite has the rekitted carby found a tuning problem on your car.
    Jun 2003
    Launceston, Tasmania
    Fuel pump or vacume advance would be worth looking at.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Sounds like a timing issue caused by either dodgey vacuum advance or spring weights (have they seized) or both in the distributor.
    Gazzz
    Adelaide - Torrens Park
    Possibly running too lean, suffering lean burn miss / backfire.
    Perth, Western Australia
    It does sound like an ignition issue to me. Stupic question but did you replace all the plugs along with the other ignition components?
    Williams West Aust
    Im with Big John
    Running lean.
    Possible that the carby gasket is leaking,or even the nuts on the carby come loose(MY BET!!!!!).Been there done that with the same carby conversion!!!!
    A good way to check for leaky gaskets is get a can of CRC type stuff with that little tube they supply.With the engine ideling spray along the gaskets,if the revs pick up youve located the leak.
    Let us know what you find.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    I see three possibilities:-
    1. (Most likely) Fuel restriction, either a fuel pump fault, a partial blockage on the suction line such as the screen in the tank, or an air leak somewhere in the suction line.
    2. Ignition - in view of what you have done, have you rechecked the points gap - I have seen this when the points close up, possibly also wear on the shaft bearings. Could also be incorrect timing due to the vacuum advance not working or the centrifugal advance seized or otherwise not working. Could also be a sick coil, or bad connection somewhere, a prime candidate being the internal earth wire between the contact breaker and the distributor body - if it is broken but making contact until the vacuum advance is in a certain position, this could account for the symptoms.
    3. Air leak somewhere into the inlet manifold as suggested.
    Darwin NT
    G'Day Guys,
    Thanks for all the good advice, will start working my way through the things people have suggested this weekend. One other thing I wanted to mention was that when I was replacing the 'points', I took out the base plate of the dizzy because the whole inside of the dizzy was covered in 38 years of crap. When I put it back in I noticed the there was a small pin on the underside of the base plate that was supposed to fit in an eyelet (which is attached to the vacuum advance shaft thingy???) and I reckon I didn't get the pin back into the eyelet... Could this prevent the vacuum advance from working and therefore retard the engine??
    timbo
    Quote Originally Posted by btm View Post
    G'Day Guys,
    ..... Could this prevent the vacuum advance from working and therefore retard the engine??
    timbo
    Yes. The exact effect will depend on whether you set the timing static as in the book or used a timing light with the engine running, but it will disable the vacuum advance - so the timing will be incorrect except at one throttle opening.
