Results 1 to 10 of 16
Thread: D2 ACE breakdown
    ATLandy Guest
    D2 ACE breakdown
    Hi all ,
    Was driving my D2 on the highway when ACE amber light came on . I slowed down but continue driving . 15 mins later heavy smoke was coming out from under the bonnet with a squeaky engine . Opening the bonnet showed the source of smoke was coming from the ACE pump pulley bearing and the ACE fluid was empty . Couldn't drive it anymore and have to wait for a towtruck .
    Why wasn't the ACE light red when the system have a serious issue ?
    At the local LR workshop , there is another D2 with similar ACE problems which the workshop have changed the pump assembly , ACE valve block , ACE piping ( unable to bleed ) and ACE still not worky . Is this a common issue on D2 ?
    Ta.
    Williams West Aust
    First Ive heard of an ACE problem.Yet another feature I can lookforward to I guess!!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    99.87 MB
    I reckon you just got unlucky. You barely ever, if ever hear of ACE problems. Recently I'd heard of one in the states that had some corrosion near the rear hydraulic I think it was. Thats about it.
    Slunnie
    NSW SW Slopes
    Not able to help on your problem, but just a few days ago I obtained and tested a shorter belt that bypasses the ACE pump on my TD5 for emergency use. The original belt was 7PK1870 and the shorter one is 8PK1560 cut down to 7 ribs (7PK1560 equiv).
    May 2003
    On The Road
    so it failed from lack of fluid??
    or a failed bearing?
    Douglas Park, NSW
    Normally the pump fails from oil loss through a leak somewhere.
    The amber light would have been a warning so it probably wasn't wise to drive on. Easy to say in hindsight I guess.
    May 2003
    On The Road
    have you seen many fail Scott?
    Douglas Park, NSW
    I don't know if I should answer that .
    It's not that common really. Usually a leak is noticed first & fixed before the level gets very low.
    I would say that we might get 1 or 2 like that in a year. Maybe non-LR dealers see more.
    Adelaide - Torrens Park
    In the 2.5 years I have worked here we have replaced one ACE pump. A fluid line was torn out under the vehicle, then the pump failed due to running dry.
    Williams West Aust
    What oil is used in these,or more so is there other compatible oils?????,mines down a bit but couldnt get the recomended stuff from supercrap,repco or Malz.
    Andrew
