Thread: Cheap ODB-II Scanners & TD5
    robert4wd Guest
    Hi
    there are a number of cheap ODB II scanners on eBay, has any one tried one with a 2002 Defender TD5?
    http://cgi.ebay.com/ebaymotors/ODB-I...mZ190083620753
    Robert
    Kyabram, VIC 3620
    Quote Originally Posted by robert4wd View Post
    Hi
    Robert
    Strange this question should pop up, I have one, and just this weekend at the Wandin 4x4 show I had the chance to try it out on a TD5.
    No it doesn't work.
    It works fine on my V8 Disco II
    .........but it didn't work on Ray's (Hiline) TD5
    Kyabram, VIC 3620
    From the manual - it seems to depend on the amount of connections/wires in the socket on the vehicle - and when I tried Ray's I noticed there were only a few wires into the diagnostic socket under the seat.
    Not sure what year Ray's TD5 was/is
    robert4wd Guest
    Thanks will save my money :-)
    Quote Originally Posted by ladas View Post
    I believe the OBDII socket on the V8 and Td5 is wired the same. I suspect the issue is that the system cannot hand shake with the Lucas Td5 ECM. No Td5's in the USA!
    Kingston, Tassie, OZ.
    Correct, only talks to Bosch Motronic V8 D2. And lots of other makes also, but no Td5, GEMS or EDC etc.
    JC
    I have an OBDII reader also and have worked out that it is no good for clearing the ABS/ETC/HDC lights which is what I got it for. It was worth the chance.
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
