Results 1 to 10 of 22
Thread: gas strutts on defender bonnet? yes i have!
    Padstow NSW
    took about 3months to think about doing this job and 30min to actually fit it
    usuall story had some strutts sitting around and some alloy angle, next thing ya know presto!
    cheers phil
    just have to tidy up the edges on the brackets.
    Eidsvold QLD
    great, can you post a pic of the bottom mount??
    Padstow NSW
    the strutt's i use have a ball joint on the end. had to drill one 5/16 hole in the inside of the wing top. only on the pass side there is a hole in the drivers side thats got a clip in it for the radiator over flow pipe bracket.
    cheers phil.
    ps. one strutt will do the job but it must be around 300nm. the two i use are 150nm's each. i had bigger ones but they were to long
    Perth WA
    Thumbs up
    Discowhite
    Thats a great idea... What length are the struts that you used?
    I might have to do somthing like that myself.
    Craig
    Alstonville...is near Byron Bay
    Good stuff and well done!
    I'd like to do that to the Disco.
    GQ
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    You've now hexed yourself by planning to have the bonnet up so much.
    Padstow NSW
    no its just that if it dose happen it happens in STYLE
    lengths are 600 open and 480 closed. 150Nm each strutt.
    cheers phil
    Padstow NSW
    yep but it wasnt mine
    i read alot of mag's.
    cheers phil
    My bonnet is up right now - waiting for some p/steering juice - funny about that! Yep its leaking again...............
    GQ
    Let's workshop this for a minute.
    You HAVE hexed yourself, but for the sake of the argument let's just think you've been extremely unlucky. Scenario is:
    1) Schtuffed oozidoobit has stopped forward progress.
    2) Fender is now known as "flunking piece of schnitt car".
    Now, if we're doing this in style.
    2) Fender is now known as "flunking stylish piece of schnitt car".
    So there we have it. For the extra pfffft struts instead of a poo, you have a poo with sunglasses.
    Was it worth the extra?
