On rechecking the price was actually $68 delivered.
The company is Outback 4x4 Gear
Postal Address:
Outback 4x4 Gear
PO Box 18,
Baulkham Hills
New South Wales 1755
Australia.
Tel 0404575751
www.outback4x4gear.com.au
This is the item that I bought - it works well and has great reception inside and in heavy rain.
BRAND NEW GPS RECEIVER BY
* * Just Released * *
The Altina GGM309U GPS Mouse Receiver
with the latest SiRF III Chipset
USB Cable Connection.
Shipped from within Australian NOT overseas, so you have no more additional charges except postage.
<img>
The
GPS Mouse Receiver-GGM309U incorporates the latest SiRF III chipset giving you faster acquisition and reacquisition times and up to 20 parallel satellite channels. The
GGM309 enables you to receive GPS data on Smart Phone, Pocket PC, Notebook & PDA with wires. The
GGM309U receiver provides high position accuracy and has reliable tracking capabilities. The device can provide you with an easy means to find the correct direction to where you need to go with the appropriate software. The
GGM309U also saves critical satellite data by means of a built–in backup memory, powered by a internal battery charged during normal operation. The
GPS unit is water proof by design allowing for the devise to be mounted externally on the vehicle roof etc.
What's Included In The Box
General Specifications. Frequency: L1, 1575.42 MHZ C/A Code 1.023 MHz Chip Rate Channels 20 Format: NMEA0183 V2.2 Chipset: SiRF Star IIe/LP3 Selectable Baud Rate: 4800-Default, 9600, 19200, 38400 bps GPS Protocol Default: NMEA 0183 v2.2 DGPS: Position Horizontal: 1 to 5 meter Velocity: 0.1 meter/second, without SA
Acquisition Time (averaged) Reacquisition?0.1seconds Cold start? 50 seconds Warm start? 38 seconds Hot start? 2 seconds Update rate?
Dynamic Altitude: < 18,000 meters Velocity Limit:< 515 meter per second Acceleration Limit:Less than 4G Jerk:20 meters per second / Max Interface Connector Interface: USB Cable Length: 1500mm Datum?WGS84 Physical characteristic Dimension: 60(L) x 40(W) x 17.3(D) mm Weight: 40g Input Voltage: 4.5 to 5.5VDC; non-accessories Backup power: 3V rechargeable lithium-ion battery; up to 500 hrs discharge Environment Operating Temperature: -40 °C ~ + 85 °C Storage Temperature: -40°C ~ + 100°C Humidity: 5% ~ 95%; non-condensing Note: Also available with PS2 connectors.
