Results 1 to 4 of 4
Thread: OziExplorer
    OziExplorer
    High all - GPS/Laptop system is coming along really well - I have just switched from using the trial version of OZiExplorer to the full version.
    Two questions - how do I get it to display speed and height while in moving map mode, and
    Apparently OziExplorer can join various maps - my scanner is A4 and I want to scan in my local topo maps but they are far too large and I will have to scan them in as sections - as I said OziExplorer can rejoin them but I don't know how - any thoughts?
    May 2002
    Heathcote (in "The Shire")
    Garry'
    I've never used it but I believe the utility you are looking for is an add on to Ozi call MapMerge
    http://www.oziexplorer3.com/mapmerge/mapmerge.html
    For speed, Altitude etc open MOving map control when in moving map (under the moving map menu)
    Martyn
    St Helena,Melbourne
    4.28 MB
    You may need to turn those features on, possibly in configuration ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Bushie/Loanrangie - thanks for the tips - found the spped/height menu and I will scan in a topo and see how the map merge works.
