Results 1 to 10 of 13
Thread: Swaybar Disconnects D1
    Melbourne, outer South East
    I have removed the photos and description of this due to points raised in the follow up replies.
    If you want the details please PM me.
    Feb 2005
    good work and simple,
    the only thing i can think of is lateral movement when flexing the suspension while they are still connected, i'm guessing there would have to be a bit so maybe that nail might not last to long, a local engineering shop would weld the washers on for nicks, might be a good idea to stick your head under the rear after every other drive to mae sure everything is in place
    legal, well i'm sure somebody will comment
    well after reading this post i would do the mod if i owned a disco
    Kyabram, VIC 3620
    Very nifty Wayne, I like simple Ideas.
    I would agree thought that the nail might be a little weak, and I would certainly look at welding the back washer in place, and a nice chunky one.
    Thanks Kevin /Ladas - yes good idea I will get it welded - the nail is only temporary to test the theory. I will put the original bolts back in till then.
    May 2006
    Greenbank Brisbane, QLD
    Great find, I'll be copying you with setup. Thanks
    I agree with the others. Thanks for posting.
    Mar 2007
    Living the dream!
    great job, will be adding that to the "to do" list
    am very curious about legalities.
    only illegal when you get caught
    Mansfield, Victroria
    Quote Originally Posted by SSmith View Post
    or have a prang - and insurance knocks you back
    or hit someone and they charge you as your vehicle was faulty.....
    but im sure that a judge will see it your way....
    sorry just being the devils advocate
    Mick
    Narre Warren
    Had the same thought over the weekend of the Toolangi Trip. ended up just removing altogether. Not too bad, just slow down a little in corners.
    Melbourne - Eastern sector
    a few years ago i spoke to an engineer about sway bars as i removed them from my rangie. It is illegal in Victoria to remove sway bars if it came with them. I know with my rangie when i get it engineered for the ute conversion he is going to cert it without sway bars. anyway getting back to the original question about quick disconnects well he seemed to think they were highly illegal due to the fact they could come loose and the driver may loose control and or roll the thing.
    Mick
