Did you email the manufacturer ?
Do you need exactly the right driver for your GPS reciever or are there universal drivers?
I have lost the driver for mine and after much searching on the net I can't find one anywhere. I can't even find an english speaking shop that sells the reciever.![]()
It is a G mouse TP-051.
If you have a driver for a different kind of G-mouse maybe you could email it to me and I will give it a go. It is for Windows XP and you can email it to info@infraredsolutions.com.au
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
USB or serial?
Ron
USB.
Yes I have emailed the manufacturer twice. It is Techway in China but after over a week I still have not had a reply
GD Techway in Shenzhen or Techway electronic in Taiwan?
my mandarin is rudementary but I can probably read enough to find the driver
is it this?
http://www.billiggps.dk/shop/information.php?info_id=7
either way, if you open up the case, you will find the chipset and this should provide you with more posibilities
GL!
I pulled my unit apart and found a Polstar PSG101 module inside.
The following driver worked for me, it is a USB to Serial driver and is actually quite common.
http://www.polstargps.com/html/G-Mou...-downloads.htm
Stephen
