Results 1 to 10 of 11
Thread: Drum Cleaning
    VIC
    Drum Cleaning
    I bought a 205L HDPE drum from a crowd over in Campbellfield with the intention of using it to store bio-diesel. I was assured it had been filled with primrose oil only, so I duly bought it and embarked on the job of cleaning it out today.
    I have no idea what was in it, but it certainly wasn't primrose oil. There was about 500mL of residue in the bottom, I flushed it with [stained] tank water but when I poured the "substance" out it fizzed like hell. Then I found the torn off remains of a "corrosive" label on it. Great.
    So I've since flushed it out with copious quantities of tank water, cleaned the insides thoroughly with diluted 1:40 degreaser, rinsed it well, then cleaned the insides again with approx 500mL unleaded petrol, rinsed it all out, dried it as best as I could and left it inverted with the caps off to ventilate/dry out.
    Will this be sufficient or is there something I have missed?
    May 2002
    Heathcote (in "The Shire")
    If it fizzed when poured out onto concrete it was most likely acidic.
    Not withstanding any other real nasties that may be associated with it, a good flush with a heap of bicarb should neutralise the acid.
    Personally without knowing what may have been inside (think pesticides, herbicides or any of thousands of chemicals) I would chalk it up to experience and dispose of the drum properly.
    Better safe than sorry.
    Martyn
    Id flush (bout 30l at a time and roll the drum round with the bungs on) with
    1. baking soda and water
    2. water
    3. soapy water
    4. water
    5. 2-3l of metho
    but as youve done most of that just doign a final with metho to get the last of the moisture out and letting it sit in the sun should do you right.
    South Yundreup,WA.
    I would be querying why they sold or gave you a drum that had acid residue in it. This is illegal without appropriate licencing and labelling unless it has been cleaned out properly.Labels must be clear and legible even in empty drums, msds sheet should also be given with it. It is a requirement that companies disposing of drums have them steam cleaned and all labelling removed.
    As said Bi-carb should neutralise it as will lime (but then you have an issue with lime).
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Tregeagle, NSW
    Take it back and get up them, and get a clean replacement.
    john
    Alstonville...is near Byron Bay
    I've bought more than 100 of the blue drums and all were well cleaned by the supplier. One is currently doing service as a fish tank and the fish are just fine. No mutants yet
    GQ
    from where and how much do you want for some assuming your near brissy?
    VIC
    I'm in Melbourne
    I spent today giving it another clean out and hope to fill it next week. It seems to be fine now, but in future I won't be returning to that place. I'll find some in the Eastern Suburbs(runs and hides)
    May 2003
    On The Road
    Quote Originally Posted by Quiggers View Post
    GQ
    if the drums are blue--
    how do you see the fish?
    1. Point shottie at top of barrel.
    2. Pull trigger.
    3. Watch fish float to surface.
    Simon
