[quote=fossil;523060]In the last week or so the aircon compressor in my D1 TDI seems to be playing up. When I start the car from cold for about 10 - 15 seconds the magnetic clutch continually engages and diengages making a loud clicking noise. It doesn't do it all the time but most times when it is cold. I haven't noticed it happen when the engine is hot. It doesn't seem to effect the working of the aircon as it still cools OK. After the initial 10 - 15 seconds it seems fine.
Has anyone else had this happen or has anyone got any ideas why it is happening and how I can fix it.
It could be just dirt/grit/dust in it, then just remove, clean with kero/white spirit/petrol ..........wipe clean, leave to dry out then reasemble.
However it could be the windings in the clutch getting weak, difficult to diagnose, but if the clean out doesn't work It would my guess that is the problem.
If it is - you need a new clutch.
Not hard to do.
