Results 1 to 10 of 12
Thread: moving engines ??????
    Caboolture
    I am looking at an engine on fleabay its a 2.25 purely as a total strip down and rebuild exercise. Only problem is getting it from sellers house to my shed. Is there a simple way to lift and transport an engine around the place ???? Once ive got it sorted an engine stand would have to be purchased etc. Any thoughts?
    Mick
    Williams West Aust
    Hi Mick
    Small block and tackle to lift it up back your trailer under it lower into trailer.
    Get a stuffed tyre to sit the motor in,31x10.5x15 or similar work good.It will hold the engine upright enough without damaging the sump.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Caboolture
    Thanks Andy, only problem is no block and tackle mounting points (roof wise) Good tip on the tyre though.
    You could hire one of these:
    Kennards have them.
    Simon
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i have block and tackle if you need one, uncleho has a floor crane, he also has a trailer with big dint in bottom from my 2.25 diesel :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Three lengths of 2" scaffolding pipe, drill a 16mm hole two inches from the end of each, and join them with a 1/2" bolt - the oversize holes will allow you to spread the legs sufficiently to get a box trailer under it. Length of pipe depends on how much overhead you have - I used to use 10ft. Now use a ute crane mounted on my tandem trailer.
    Alternative - six feet of same pipe, plus four blokes, two on each end.
    May 2006
    Redesdale, Victoria
    saw an engine crane for next to nix in an ad.....now where was it?
    QLD
    any mates have a little crane like a Hiab or palfinger, even tailgate loader....that's the easy option...straight on the back.
    paul
    Yass NSW
    I have used John's method and it works well. I have also used the stupid adrenaline method with a friend where you both lift to the point of no return and rely on the pain and adrenaline to finish before you injure yourself.
    Ipswich QLD.
    I have a floor crane you could borrow, but Uncle Ho is probably closer. (Mine is at Ipswich)
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
