Results 1 to 10 of 13
Thread: Ummm arr crap - Passenger Door - Def..
    Bexley NSW - Sydney
    The little woman got in the car today, shut the door and thats where its staying ... for some reason it will not unlock or open .. the button actually feels like its not activating anything ..
    So I can not open the door, I can not remove the cover (door is shut) is the only other option taking it off at the hinges .. or could I / should I call nrma to 'break in' ?
    The key / lock does not turn around all the way, and the button / leaver does not go all the way up either!
    Any ideas ?
    Sussex Inlet. N.S.W.
    Is your better half still stuck in the car?
    Bexley NSW - Sydney
    Quote Originally Posted by jx2mad View Post
    Nah she climbed out over my lap so it was not all a bad day ...
    but now wondering what to do !!!! I think the hinges need to be removed .. what a ****.
    Jimboomba, QLD
    I'm not familiar with the locking mechanism on Defenders, but I think that removing the hinges will probably not help. The latch will still be attached to the locking pin and the door can't simply be pulled off.
    You could remove the seat to remove the door trim. Otherwise NRMA may be the best option (if the mechanism isn't completely jammed).
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    If all else fails you can pull the surround from the lock lift tab and get access to the innards of the door through there. Replacement bits are pretty cheap.
    I don't think you can get the door card/trim off without opening the door.
    I've had a similar problem before, where the lock tab just won't work. It seemed to be due to accumulation of dust in the various bits of door lock. Sorted with a clean up.
    I've also found that if you keep at jiggling the tab it will eventually come good.
    Simon
    Try using the "coat hanger wire" trick to unlock it from the outside.
    You'll probably need something stiffer than a coat hanger (otherwise fold it double for rigidity). The mechanism is in the corner where the lock is. When I locked the keys in the Defender, I tried to do this for about half an hour, the RACV arrived and unlocked it in <30 seconds. When I again locked the keys in the Defender it took me about 5 min to get the lock open.
    The Roadside Assist people have a hook just the right shape. If you do call them, memorise the shape.
    Anyway, unlocking the mechanism will hopefully allow the door to open. One of the linkages in the door has probably come loose or broken. They're cheap, make sure you clean & lubricate all the parts when reassembling.
    St Helena,Melbourne
    4.28 MB
    Nah, undo the hinges, they are external and then the door will just lift out. Then you can remove the trim and fix it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NOOOOOOO!!!!!!
    I think that the lock will still hold the door into place and you're only going to bend something trying to pull it off by removing the hinges.
    Kyabram, VIC 3620
    The lock is a 'hook over pin type' and therefore will not allow the door to be removed when closed/locked.
    Kyabram, VIC 3620
    I would be pretty certain that you could get enough of the top of the door trim off to allow you to get a wire hook in there to unlock it.
    You would only have to open the top by 3 or 4 inches, and with the aid of a torch and good strong hook - tent peg comes to mind - and hook it round the latch bar.
