Results 1 to 10 of 31
Thread: How Useless is the Front Tow Point on a D2?
    Oct 2006
    Boronia, Melbourne
    Everyone tells me to never use the front tow point for recovery, but really how weak is it?
    Looking at it from an engineering point of view it looks reasonably solid, sure i reckon it would bend, but i dont think it would snap?
    Adelaide Hills. South Australia
    I wonder if it's for a tow recovery & transport tie down only?
    I don't think I would be doing a snatch recovery with it.
    My D1 has a welded loop only & is a tie down point only, acc. to LRA.
    Is there no mention in the handbook?
    Well actually the D2 which you have there is alot better than the D1 or RR classic and Defender. They beefed them up on the D2 as everyone was useing the tie down points (for transporters ) as towing points so land rover beefed them up. But i would still not trust them for snatch recovery or any heavy recovery
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Caboolture
    flat tow, tie down yes. winching i personally wouldnt. Snatch definately not. It all comes down to kinetic energy
    Feb 2006
    gosford
    Don't even think about it. As said above kentic energy.
    Quite a few years ago a child was killed on (Morton Island can't remember which one now)? I think that was the one, any way, when someone snatched from the tow ball, the ball became a missel. It might look strong but unless the load is spread across both sides of the chassis I would not risk it.
    This was the first mod I made to my D2 before I went to Fraser last year.
    Hi GB,
    I have seen this snap twice..DONT use it..
    I have some thicker plates on mine from a company called www.4x4intelligence.com.au
    Its ok to use as a minor tow rope(if u have too), but with no force. Its just not worth it.
    Oct 2006
    Boronia, Melbourne
    I actually sent an email to 4x4 4x4intelligence this afternoon and received a reply from Simon.
    The recovery points are sold as a pair but i would need to cut a hole in the bumper to use the second one which im not intending to do.
    But i will buy and install both just the same, the 2nd one would be there but not accessible
    May 2003
    On The Road
    unless the new ones stick out substantially,,
    on anything but a straight pull the skirt will still cop a flogging,,
    but,, if the tides coming in---
    NSW SW Slopes
    I cringe at the thought of using those brackets. The top bolt becomes the pivot and the bottom bolt takes all the force multiplied by 2 due to the lever action. Sure the bracket looks and probably is very strong but with the mounting, is it really any better than the LR tow hook (which was strengthened on the D2a)? The top bolt would not be subjected to the same multiplied force after the bottom bolt sheared, but its still just 1 bolt again.
    As I have a bar and winch I have been able to mount a recovery hook to each side of the winch cradle. They point down slightly so the angle of pull is not strictly horizontal with the bolts but I guess that I get about 95% of the load capacity of the bolts as a pair.
    I'm much more comfortable with my setup, but its of not much use to others without the cradle for a mount site.
    Caboolture
    My understanding of these points is that they mount horizontally along the chassis rail. Using rated HT bolts this would mean the direction of pull is inline with both bolts and directly through the rail.
    I have been known to be wrong before though
