Results 1 to 10 of 14
Thread: need more storage?
    May 2003
    On The Road
    need more storage?
    Brisbane, Queensland (Australia)
    That's a lot to loose when it dies.
    Jun 2003
    Launceston, Tasmania
    1 terabyte !!!! and I thought my 300gb drive was overkill!!
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Alstonville...is near Byron Bay
    Finally, a 1 tb hard drive.
    That's gonna be a heap of data lost when it expires
    (I prefer raid arrays).
    GQ
    Yass NSW
    We have one in an external case at work for back ups and data transfer. It's great!
    Quote Originally Posted by Quiggers View Post
    GQ
    That's a big drive and pretty dam funny that it's a Deskstar. Before Hatachi bought IBM drives the deskstar was known by IBM staff as deathstar as it wasn't a if the drive would die but a when.
    I won't be moving my TB of storage off my raid array any time soon, drives just aren't reliable enough. Although an array of 1TB drives would be cool, 3, 4, 5 TB without the need for server specific hardware, hrmm nice.
    Best regards
    DarrenR
    Mirrored pair would be the only safe way, that's a lot to loose!
    Now if cost wasn't an issue hmmm RAID5 ... how long before Petabytes really make themselves felt
    Maleny, Queensland
    You should just make sure you get THREE. One primary, one RAID1 mirrored, and one in an external caddy with scheduled backup. That's really all you need to be safe.
    I am not sure why more people don't get RAID1 setups as standard. Unless you're using a laptop, then simple technical failure of one hard drive is the most likely cause of data loss. Of course if you ARE using a laptop, then theft is the most likely cause.
    Oct 2006
    kinross, Perth, WA
    just in their defence... im running 8 of the 500gb versions.. and have used literally thousands in the past... as i designed raid storage kit.. and we used hitachi exclusively...
    as some guys have stated tho... raid is the way to go.. i have mine set up in a raid 5 array.. the advantage being i only lose 1 disks worth of capacity rather than half of the total number of disks capacity.. 1 dies.. i replace it and it rebuilds.. i still back up all my 'important' stuff like pictures and docs to an external 500gb too...
    The hitachi drives are wickedly quick too!
    Steve
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by 5teve View Post
    ibm drives were always quick, but deadly, many sizes had a near on 100% death rate at 3 years.
    is a pity hitachi and/or their distributors are also renown for not honouring warranty... not a model i like to put any of my clients thru...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
