Results 1 to 10 of 24
Thread: D3 Low Ground Clearance
    Parked my Freelander next to a base model D3 today. When coming back to the car it was clear that my Freelander (225/70 tyres) had just a bit more ground clearance than the D3. On having a closer look the clearance under the front diff was about the same, but the D3 was a little worse at the rear. I know it is superior on paper but looking at the cars would indicate otherwise.
    Looking at a few other brands the D3 clearly has worse clearance than other full on 4x4s and about the same as most softroaders. I appreciate if optioned with air suspension - ground clearance can be great but the standard car seems awfully low for a full on 4x4.
    Clearly the D3 is marketed as a fully capable offroader but given its low clearance this would seem to be a bit of a stretch for the base model. It would be certainly less capable that my old D1 and on about on par with my Freelander when the D3 was in high range.
    Any one with a base S D3 care to comment on how they find ground clearance in the real offroad world.
    Williams West Aust
    Hi Garry
    The D3 sinks to park height with motor off,has a "normal" running height,grows a taller for off-roading,and when your stuck it will go taller still.
    The diffs on the D3 are tucked up in the chassis so the have HEAPS more under clearance than a normal off-roader.
    The coil sprung versions are basically D2 suspension,but with the added undercar clearance as the diffs arent under there.
    If followed Gordons D3(GGHaggis) offroad on several trips,the clearance is very good for a stock standard vehicle.
    Im guessing you parked next to a D3 with air suspension,yes when parked they are lower than normal offroaders.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    St Helena,Melbourne
    4.28 MB
    The spare wheel location is the real downfall in the clearance department, wheel carrier would be first on my list.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hi Garry
    Andrew
    The car I was parked next to had coils so that ride height is fixed - I understand that a standard D3 has only 185mm ground clearance - a standard Freelander has 200mm and mine about 210mm.
    The rear tyre seemed to be mounted up higher - certainly was higher than the rear diff mounting framework - the rear shocks also seem to hand down low as well.
    Williams West Aust
    Fair enough Garry
    Only seen Gordons and Jamos D3s in action,both have air suspension,BLOODY GOOD VEHICLES!!!!!
    Andrew
    Nedlands, WA
    Coil sprung D3 does sit a bit low, but wheel travel would be far superior to the Freelander.
    Melbourne, Australia
    Some of the coil sprung D3 owners I've heard about have fitted aftermarket springs like King Springs to give it a lift.
    The D3 S with coils was tested in some of the 4WD mags and it has far less ground clearance than the air suspension versions and had a tendency to drag it's belly on the ground.
    Chris
    Nanny state UK...
    The air sprung versions have an awsome amount of clearance.
    Even after you put it into off-road mode, there's 2 other further height settings available. These settings are not intended for general use but are designed to get the vehicle out of difficulties (or further in depending on how you look at it... ). As such you can't manually put the car into this mode, it has to detect that it is bottoming out... From there it will raise the height further. Once raised, there's a sequence which you can follow to raise even further.
    HTH
    M
    yep, I have to agree,
    my d3 coiler has **** clearance.
    I need to find a way of giving it a bit of a lift.
    not interested in your comments re air suspension, this thread isn't about those cars.
    are there any d3 coiler owners that have raised their cars?
    Safe Travels
    harry
    May 2010
    brighton, brisbane
    Quote Originally Posted by harry View Post
    Perhaps you should try the D3/D4 section, plenty of info there, Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
