Results 1 to 10 of 17
Thread: Extender Lead for Camper Trailer
    Brisbane, north of the river
    G'day all,
    One of the "optional accessories" for my camper trailer is a 6m anderson plug extension lead for when you need to plug your camper into the vehicle whilst camping.
    Currently my Camper has a Solar panel and a battery, however the battery is a cheap-ar*e maintenance one that only has 450 CCA (not that it would ever be used for cranking, but just for general information). This is because the camper I have is ex-demo and that was what the dealer put on their demo stock - cheap, cruddy battery. However it *is* a working battery so I am loath to change it until I kill it.
    The problem stems when I am running the 80ltr fridge for more than a day without being connected to some form of external power. The fridge draws variable amperage from 0.5 to 4.5 AMPS Maximum (direct from manufacturers website) and after about a day and a half the battery in the Camper is dead - and it usually happens at night as the Solar panel seems enough to keep everything happy, but once the sun sets......
    Anyways was just wondering if it is worth purchasing a 6m extension lead - I have a SC80 in the vehicle setup for a 3 battery system and it works well..
    It would just save me having to reverse the vehicle directly up to the camper in order to connect up overnight to keep the fridge running..
    Your thoughts?
    Dalby
    Sounds like a good idea. Sometimes you can't get your vehicle in front of your trailer anyway.
    Dependent on cost though I'd probably make my own.
    depending on cost make your own... or invest in a second panel to keep the fridge happy.
    Kyabram, VIC 3620
    Make your own
    The cable and anderson plugs from Traxide are
    10mm twin cable (45 amp rated) @ $12.00 /m $72.00
    Two anderson plugs $12.00
    $84.00, plus postage and about 15mins and a bit of solder - jobs done.
    Dalby
    Quote Originally Posted by ladas View Post
    Unless he has a bigger than average soldering iron or even a mini blow torch then I think crimping would be the go.
    Queensland
    Hi folks, Grizzly PMed me about the extension lead and I suggested to him to post the question here to get some ideas.
    I also offered to make him up a 6m extension lead using 10mm2 twin cable, two Anderson plugs and two Safety Covers for $90 including post, plus I can make the leads longer if required at $10 for each additional metre.
    There is another way to charge the camper trailer battery and that is to connect a 12 to 240v inverter to the vehicle’s battery when you come back to the camp site and run an ordinary 240v extension cord to a small battery charger in the camper trailer and let it run all night.
    This set up has the advantage that the vehicle battery is charged while you are driving around during the day and then it is used to charge the camper trailer battery at night and it does not matter if the vehicle’s battery is lower than the camper battery as the inverter/battery charger set up raises the voltage going into the camper battery anyway.
    Ellendale Tasmania.
    I've done this on my setup, i also have an elcheapo 75AH battery in my camper and a small solar panel to keep it charged during the day (i don't have a fridge running of it though) and after a few cloudy days the near the end of one of our stays in the bush the water pump was starting to show signs that the battery in the camper was running flat, so that night i hooked up the camper battery to our battery fighter charger and ran it off an inverter from my auxillary battery in the car.
    Next morning battery was recharged and i went for an explore to recharge my auxillary battery in the car and all was fine that night
    I saw Tim (drivesafe) mention this in another post and thought now that's worth trying, so i did.
    Oh BTW Tim new smart charger is going great, no probs at all
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Wouldn't the cost of the inverter be more expensive then just getting the cable made up?
    Queensland
    Quote Originally Posted by Grizzly_Adams View Post
    Yep, but as many people already have either a battery charger and/or an inverter, the cost is not that much, if anything.
    On the other hand, if you have a cable running to the rear of your vehicle with an Anderson plug on it, then an extension lead is a simple alternative and the extension lead can be used for other things such as powering a compressor or running accessories like a fridge or lights without having to have to have the vehicle right there to connect directly to the battery.
    I have an Anderson plug on a short lead at both the front and rear of my rangy and have a 5m extension lead to run what ever I want.
    Cheers.
    Queensland
    Quote Originally Posted by Redback View Post
    Baz.
    Good and stage 2 should be ready for testing very shortly.
    Cheers.
