Results 1 to 10 of 15
Thread: The prince of darkness strikes again
    Maryborough QLD
    Exclamation The prince of darkness strikes again
    Well thew title says it all, the Rangie has had a bit of a electrical meltdown.
    Was giving the Rangie a bit of a run down the M1, all was good and I have now solved the fuel tank issue thinking all was good (put a stock fuel tank back in, forgot how much clerance the LR tank took up )...or was it ???
    One of the looms decided to fuse together, with smoke pouring into the cabin this isn't a good thing. Luckily I was just around the corner from home when it sll started, so I got it hone, disconnected the battery to save more damage. After the 'meltdown', I inspected the loom and the entire section from the passenger side to the the fitting near under the bonnet is fried. Not good.
    Off the the sparky tomorrow, just have to wait til I get a nasty repair bill More trips now put on hold due to repairs. Still have a bit of a list to sort through as well so I might be quiet for a while.
    Trav
    Free Again Thanks Dan
    Quote Originally Posted by aquarangie View Post
    Trav
    OOPS ! bad luck dude hope you get it sorted soon
    Maryborough QLD
    Thanks. Dodgy 20 year old Lucas wiring has a tendancy to do that I guess
    Love to be able to DIY but I am a total novice to electrical (can do basic stuff but not re-wire loonms sort of thing).
    Trav
    Piggabeen (Tweed Heads)
    Looms
    Depending on how many wires are in the loom Trav, you can do it yourself with some multicore trailer flex. Its just a case of cutting out the melted section and soldering in a new section. You can use heat shrink on the joins and then put in in flexible conduit. You only have to join the correct colours at either end.Its not that difficult and will save you some dollars.
    Justin.
    ps pm drivesafe he could get the multicore and plugs if req for you.
    Maryborough QLD
    No worries thanks Justin. You leave me with something to think about and something to do during the week
    I can unplug one section of the loom all I have to do is find the other end and sort it out I guess.
    Trav
    I know its probably too far but If you want a hand to DIY it let me know...
    I had a hoist reserved on friday for a service but the bloke who I was doing the oil change for needed it more urgently than he reckoned as hes now siezed the donk.
    Maryborough QLD
    A bit of an update and the news isn't good I hate to say.
    The air con harness as well as electric mirror harness are knackerd, plus the wire that was the main culprit goes deep into the main loom so whilts it may be the one wire, it could be worse. Still have to investigate further before any action is taken.
    My main fear is that it could be costly and to be quite honest, the Rangie simply isn't worth that sort of money. It would be cheaper to buy another Rangie, transfer all the goodies over and keep charging on but it's a hell of a lot of work, weekends and money wasted.
    As typical as electrical shorts go, this isn't an easy or cheap fix so it will be a auto sparkys job, but will inquire a bit more tomorrow and work out some costs involved.
    Trav
    Rangie
    Trav
    I can get you a 86 manual in great nick all working for $1300.
    Justin
    Maryborough QLD
    Okay, finally found the burnt wiring and so far it looks repairable. I had to pull the heater unit out which if anyone has done it is an absolute ***** of a job and it was dead centre behind it (where the burn wire stopped)
    The wire that burnt hasn't started to burn through the rest so at this stage the beast is salvageable. The air con is fried but it wasn't bloody working anyway so that's no loss and all I need to do is re-wire part of the main harness as well as find a good second-hand air con/electric mirror harness as well. The AC compressor still works so I might re-use it and hook up an air tank to it (have one of those) like an 'endless air' sort of arrangement.
    Wish me luck everyone. Rangies are too good to wither and die
    Trav
    Maryborough QLD
    I had the sparky look at the Rangie last week as stated it was made out to be nowhere near as bad as I first discoverd. These blokes are idiots I tell you, throw it in the too hard basket and I see why I DEIY nearly everything on the Rangie
    Got all the main functions working, no air con or electric mirrors as yet, but will be getting a repacement loom this week hopefully Still sorting through wiring that either is dead as a maggot or has no real reason to be there ATM (no wonder they had so many shorts in these bloody things )
    Also I'll be re-wiring some of the accessoies which were put in earlier by me (UHF radio, etc..) and a dual battery system as well to keep the fridge running and the beer cold
    Trav
