Results 1 to 10 of 22
Thread: XP desktops
    May 2003
    On The Road
    XP desktops
    for some reason I have a list a mile long,,
    how do we go about deleteing them,,
    Microsoft tell you everything BUT that.
    have been into C;Windows\Web\Wallpaper
    but it only lists genuine MS ones.
    a lot of them are jpgs with only numbers as descriptions,,,
    You can safely delete all files from C:\WINDOWS\Web\Wallpaper (these are just default background pictures for windows desktop)
    Also you can delete all the BMP files from c:\windows these are destop tile images.
    The other images are located in the "my pictures" folder normaly located under
    C:\Documents and Settings\(user name)\My Documents\My Pictures
    Zakros
    D1 TDI 300, 2" lift kit, Maxxis Bighorns MT 265/70R16, bullbar, Dual ARB Diff Lock and UHF, the rest will come
    May 2003
    On The Road
    Hi Zakros,,
    no BMPs in C:Win
    no files in My Docs\My Pics
    I have used the search function on a couple of
    desktop img names and it found nothing,,
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    they can be anywhere on your hdd and they are mostly JPG these days..
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Simon
    May 2003
    On The Road
    give me a break guys,,
    I'd have THOUSANDS of jpgs,,,
    all I want is the ones windows uses for the desktop background,,
    there must be a file somewhere,,,
    tombraider Guest
    IIRC its just like "recent documents" and remembers where they are/were...
    Quote Originally Posted by abaddonxi View Post
    Simon
    Don't you just replace *.jpg in the search with the number that you have up in the desktop background list? xxxxx.jpg.
    That should point you to one of the backgrounds, but most likely you've got them all saved in the same folder.
    Simon
    Corindhap, VIC
    1. Right click on the Desktop
    2. Select Properties
    3. Select the Desktop tag
    4. Highlight one of the files listed in the box under Background: (I assume this is where you are seeing the list as long as your arm)
    5. With one of the evil ones highlighted select the Browse button.
    The system with then open the folders at exactly where that file is saved.
    Hope that makes sense
    May 2003
    On The Road
    Quote Originally Posted by tombraider View Post
    mm OK.
    times 78,
    see below,
    Simon
    Quote Originally Posted by Nat130 View Post
    yep. and correctamundo!
    but I dont want to delete the PROPERLY saved jpg,
    just get them out of the listed desktops.
