Results 1 to 2 of 2
Thread: Cargo Barrier for P38a
    Coolum
    Concept courtesy of G.Phillips - NOICE!
    The Milford Barrier for the VN-VS Commodore seems to be a pretty good fit for the 95-02 Rangies.
    The only mods required in this instance were cutting off the bottom half then welding on the little legs either side. However instead of welding a simple bracket could tek-screwed / bolted on.
    The top brackets align with the child restraint mounts, requiring only a little encouragement (twisting)
    You can see in the pics the bottom half of the barrier can be used as a shelf - Bloody Brilliant!
    (although a more attractive support may be used as opposed to Telecom Rope)
    Hardy
    PaulP38A, does the Rangie still have this cargo barrier fitted? If so, some pics of the mounting legs and their attachment would be appreciated.
