Results 1 to 10 of 11
Thread: towing a van bhind a discovery
    stevemc Guest
    how good are discovery v8 automatics at towing a caravan?
    we have an old van we call the retro van,and plan on takeing it away very regularly,something we couldnt do with our 4 cylinder hilux
    Echuca
    Quote Originally Posted by stevemc View Post
    They pull very well, just try and get the weight distribution in the van as even as possible (not nose or tail heavy)
    It all helps
    double check the cooler before you get serious about doing it tho... you will cook the oil if you make full use of what its capable of.
    Oct 2006
    Boronia, Melbourne
    I dont have any problems towing my Dads old 23 foot van, it takes a little while to get it up to 110km/h and it will work it hard keeping it at this speed on the hills.
    But if you take a more leisurely pace its far better, not only for the Disco and occupants but also for your wallet (fuel disappears at an alarming rate)
    stevemc Guest
    i assume you mean transmission oil cooler?
    does a 97 discovery se come with an oil cooler? or do i put one on
    stevemc Guest
    havent got the vehicle yet,pick it up tuesday,after they fix a broken mirror
    Echuca
    You should have both engine oil, and transmission fluid coolers, they are part of the radiator
    correct, you should have all the above, but ensure they are clean both externally and capable of supporting good flow, its an often overlooked part of servicing.
    Hate to tell you, but hilux's are barely capable of pulling themselves let alone a caravan, You wont have a drama in the Disco as long as all cooling systems are cleaned out
    Series 11A ex Air Force
    1995 ES Discovery TDI
    RIP 2006 Discovery 3
    RIP 2004 V8 Discovery
    RIP 95 Discovery TDI
    RIP 1999 Freelander
    RIP 1978 EX Army FFR
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DiscoTDI View Post
    Yep a lux' couldnt pull the skin off a cold custard !
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
