Results 1 to 10 of 16
Thread: Extending Wifi Coverage
    St Helena,Melbourne
    4.28 MB
    I recently bought a wifi pci card for my spare linux pc so i didnt havt to run any lan cable, but even though they are only 10m apart (slate floor and 1 wall between) i can only get a very week signal which will barely load a web page. Just been cheking out antenna's on ebay but not sure what will work the best, larger antenna on the wifi router or put it on the pci card ? saw some with extension leads and a base station type antenna which could be the go.
    Any comments or idea's appreciated. I'm using netgear modem/router and pci card.
    thanks,
    Nick.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Is the pc card power turned up to 11? There should be a power setting in the properties for the card, some default set to low power mode which gives you low quality connection. You can have the same thing on router - this time as a security measure, broadcast at lower power to limit access to only nearby computers.
    The power settings on the laptop wireless card can also be affected by whether you're running on batteries or ac.
    It's probably just as cheap to buy yourself another access point as get an antenna.
    As a test turn off all security that you have setup on your wireless connection and see if it improves the connection.
    Also check if you have anything nearby that would be blocking the signal - walls as you mentioned, but also microwave (sometimes), cordless phone, etc.
    What flavour wireless are you running? 802.11A,B,G?
    Does the router have a turbo mode? This usually only works on same brand equipment, and may make the connection slower or faster. Slower if it is trying to push more authentication data through a bad connection.
    Move router to a better spot.
    Simon
    Perth, WA
    thanks,
    Nick.
    A bigger, higher gain aerial on the AP, coupled to maybe a directional aerial on a lead hanging off the pci card would be your best bet. (If this is the only wireless client, or they are all in the same rough direction from the AP, two directional aerials would give even better results)
    But...I'd buy from a shop and try first, as wireless is very fickle, and you may find nothing helps and you're stuck with nice expensive aerials you don't need...
    Only other thing to add, which may or may not be relevent, is whether anything else is nearby affecting the signal (From AV sender, cordless phones, or other WiFi users)? If so, you need 3 channels worth of seperation between any signals in the same area...
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Another thing you could do is get something like this:
    http://www.dlink.com/products/?pid=357
    Or you could just stick another computer with a wireless card directly above the router and use it in ad-hoc mode.
    Have you tried moving the router mounting point? Mount it up near the roof?
    Have you twiddled the aerials about?
    Simon
    Edit.
    Scratch all that, read this:
    http://www.dansdata.com/io070.htm
    Dan says omni antenna sounds like the cheap way to do it.
    This topic has arisen at an opportune time for me.
    My laptop used to receive all over the house. Nothing has changed except that now it's marginal even in the next room next.
    I shall check power settings, etc.
    Ron
    St Helena,Melbourne
    4.28 MB
    Funny thing is i originally had my main pc and wifi router downstairs where the spare pc is now and i had good signal strength using my laptop ?
    I will check the power settings first then try the others cheapest first.
    1974 VW Kombi bus
    Or you could roll your own.
    http://wireless.gumph.org/articles/homemadeomni.html
    Clear as mud to me, but doesn't seem too hard.
    I can just imagine the monkeys at Dick Smith finding the parts for this one.
    Simon
    Jimboomba, QLD
    You could look at a WiFry solution!!
    These guys are getting great results using Chinese cookware as parabolic reflectors!
    http://www.usbwifi.orcon.net.nz/
    It may be difficult to explain the cookware around the house to visitors though
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Oct 2006
    Boronia, Melbourne
    Ive found channel 11 always works best with wi-fi.
    Also watch out for cordless phones which can be around the same frequency as well.
    St Helena,Melbourne
    4.28 MB
    I checked the power setting and its 100% and using channel 11 on 802.11g, cant move it closer as there is no where to move it to. Cant move the router as its on top of my pc just above the phone socket connected to the pc. I havent fiddled with the router yet so will do that and may just get an antenna and lead and see how that goes. My laptop works great outside twice as far away as the 2 pc's are now ?
    1974 VW Kombi bus
