Thread: Defender steering stop thingos??
    Eidsvold QLD
    Fitting wider tyres and will probably have to adjust, which bolty thingo are they?
    Rovernaut Guest
    Quote Originally Posted by crump View Post
    Get some one to turn the wheel full lock whilst you have a look and you will see a big bolt head that make contact with stop. Thats the one, usually it sticks out with thread visible
    look inside the front tyre. See the swival well its the big bolt that sits there and goes and hits the other side to stop the wheel turing anymore.
    Just wind out to make the wheekls stop rubbing
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Eidsvold QLD
    ok, thanks, I thought that was the one, so my turning circle is going to get even worse?
    Lyndhurst, Vic
    I have 265/75/16 on Boost alloys...........sorry to tell you Crump....It's going to get more interesting when parking and doing tight bush tracks.......
    Eidsvold QLD
    Quote Originally Posted by ciapek View Post
    and I'm going to 285/75/16s, sob.
    Im running 285/75 r16's and dont have a drama. backing the trailer or U turns..nothing touches... although the 34" Simex gave me a fright but it was just the lugs grabbing the bitumen not rubbing anywhere
