Results 1 to 10 of 27
Thread: Defender dash and cig lighter bulbs?
    Perth, WA
    What bulbs types do I need for the dash instruments (Speedo, etc.) and the cig lighter? Don't want to pull the dash out to get the type before buying new ones, that's all...
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    tombraider Guest
    Quote Originally Posted by jik22 View Post
    I'd hazard a guess and say "light bulbs"
    Sorry
    Corindhap, VIC
    We've been looking for a cigarette lighter replacement globe and the ususal places can't help us. It looks as though we will have to go to a dealer to get a replacement
    If the cigarette light bulb is the same as the P38A - they are standard 1.2 watt 12v wedge base globes.
    Does it look like this (mine):
    From my parts lists, the instruments globes in the Defender are all wedgebase. They are a bog standard item available from any auto store and even my local Woolies servo.
    The speedo lighting bulb is probably 3w (don't use 5w which are for tail lights, etc.) and, the smaller instruments use 2w, the small globes in the warning lamps 1.2w
    See here:
    http://www.narva.com.au/Globes_4.html
    As an aside, if you have an automatic Disco, there are two 3 watt globes illuminating the gear selector. Remove and replace them with 2 watt globes. If you don't the 3 watt globes will melt the plastic and you'll have to buy a new assembly. (Hmm or were they 5 watt and I replaced them with 3 watt?)
    Ron
    Defender200Tdi Guest
    T10 wedge base or LED equivalents.
    Paul
    Perth, WA
    Thanks all.
    Jeff
    2010 TDV8 RRS
    Apr 2007
    Ron
    When I was changing the bulbs in my gear selector you recommended using 3w not 5w. I went for the 3w and they work fine.
    2012 Discovery 4 SDV6 HSE
    2003 Discovery 2 TD5
    2003 Defender Xtreme
    1997 Discovery V8i
    you could be a tart like me and change the clour of them too
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Perth, WA
    Quote Originally Posted by Reads90 View Post
    Actually, that does look quite good! Is that your clock or tacho on the far right that doesn't look to have been "blinged up" in the same way though? The "problem" I'm actually trying to fix is getting my VDO tacho to light the same was as the OEM instruments, so replacing the whole lot may be the easiest way to go. Oh, plus my cig lighter socket doesn't light at all, so that needs a new lamp for sure.
    Jeff
    2010 TDV8 RRS
    Yeah been too lazy to change the bulb in the clock. will get round to it one of these days
    the other thing is that they are alot brighter than the standard ones too
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
