Can anyone quickly tell me what the defender (2001) roof weight capacity is? I recall something like 75-90kgs max, but not sure.
Jimmy
Yep... 75Kg.
Another good reason for not loading your truck up when doing a trip.
M
Jesus, I had a spare tyre, 80lts of fuel, and a steel trunk with about 30kgs of spares..
over the ruffest stuff you have seen.. and not a drama75kgs that means LandyAndy would have to cut himself in half to get on my roof rack
Remember that this is only to save LR's ass. The roof can support the vehicle when upside down, which is slightly more than 75kgs. It severly effects cornering and rollover conditions.
Thats my opinion anyhow.
Cheers!
On the last Cape Trip had a 3 m tiny, petrol and a bit of other light gear on the roof rack. It was way over loaded. The alloy roof rack cracked in two places because of the side ways movement and the roof gutters sagged. We had the roof rack on the bull bar.
Other than that it performed fine from Cooktown to Cape Melville.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
I think it also comes down to the construction of the rack, mine probably weighs in the vicinty of 60kg empty, BUT it has 12 legs so the weight is distributed over a larger area.Some of the racks you see only have 6 mounting points, 3 down each side, I wouldnt be loading them up with much.The Hannibal racks mounts encompass the entire gutter, so better still IMO.Incidentally my rack is designed to carry 6 jerries and a spare wheel, I have done a few trips with 2 full jerries and a spare with no probs and the weight is not noticeable.
A Series roof will support the weight of the vehicle, I have tried, but it may not every time. The Defender roof is cosiderably weaker so I would be hesitant to load too much. Loading fuel is probably better than tyres as at least it will get lighter on your trip.
I was on a shooting trip a while ago with two of on the roof of a Patrol (110 + 95kg) and the roof cracked.
Jeff
