Mine's a later model but the temp controls are all mechanical linkages to the heater flaps. The recirculate flap is electrical (servo) but not the temp. The outer casing of the temp 'cable' (it's more of a stiff wire) is retained by a spring steel clip. If the outer slips in the clip, the flap won't move. This may be the problem with yours; assuming of course that it is a similar system.
-- Paul --
| '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
| '94 Discovery Tdi 5spd man | going ... GONE
