Results 1 to 9 of 9
Thread: TD5 turbo spool up
    Yass NSW
    TD5 turbo spool up
    I have been asked at what point does the turbo kick in. For the life of me I can't remember. I also can't find it in the manuals. Does anyone know at what revs the turbo kicks in?
    Adelaide Hills - SA
    Nothing technical to back this up, but mine feels like it cuts in around 1800 rpm (but I have a straight through exhaust which may change things slightly).
    There will probably be a factory graph of power/torque somewhere out there to give you a proper figure.
    Adelaide Hills - SA
    Standard motor:
    Yass NSW
    Thanks. I just couldn't remember and can't take it for a spin to check just now.
    max boost will be available from just after the peak in the torque curve and max delivery just before the peak in the power curve.
    Quote Originally Posted by spudboy View Post
    Standard motor:
    Doesn't have much above 4800rpm does it?
    Williams West Aust
    That graph shows me what the D2 tells me,it just loves 2100rpm with a load on.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Yass NSW
    It is also rev limited to 4850
    Adelaide Hills - SA
    Mine sounds bad enough at 3850. Hate to hear what 4850 sounds like. I don't think my tacho goes that high!
