Results 1 to 10 of 15
Thread: Disadvantages of a Generator
    My series 1 is still running a generator but has been converted to negative earth. The charging system seems to be working fine and the engine will run fine without the battery.
    For a car of its vintage that is not going to have to support high electrical loads what are the disadvantages of staying with the generator over converting to an alternator.
    Williams West Aust
    I had a Series 2 with a generator.
    It proved to be a real pain when out shooting,the battery will not recieve the full charge at trundle around the paddock speeds.
    By the end of the nite the spotlight got quite dim and you didnt dare stall the old beast as a push start was needed.
    I fitted an alternator and all was well.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    keep it original
    no real disadvantage if you have a good battery, If you consistantly trundle around simply change the pully for a better ratio...
    the biggest one i know of is the requirement to clean the armature contacts more often than you do an alternator.
    Andrew
    But even when the battery is flat, you can still push start a car with a generator but not one with alternator as battery power is needed to energise the coils in the alternator. At least a generator does not need this and will generate enough power to start an engine when pushed start.
    I do however know what u mean with high power needs with low engine speed.
    Singapore via Melbourne
    ? I've push started alternator equipt cars on multiple occasions due to dead batteries...??
    nahh, the battery would have had at least 3-4 volts left in it which is just enoug h to fire the coil and excite the alternator...
    simulate a dead flat battery, remove the earth lead and see which on you can get to start.
    Apr 2007
    Clifton Springs, Vic.
    Mine will push start with a dead battery and it's got an alternator
    is it really posible to get less than 3-4 volts coming out of a battery? even with a failed cell I would think it will typically have this amount available. Of course with no battery present at all, I get the point that a generator based vehicle can do it, but if there is a battery and I was in that situation I'd be digging out a wiper motor and charging up the battery with that jury rigged somehow
    I have had a couple of occasions when I have left things on and the battery has gone completely dead where I have not been able to push start a car with an alternator - the first time was actually with a BMW bike.
    If there is not enough energy in the battery to excite the alternator coils then when you push start the alternator will not push out any power to provide power to the electrics in a petrol engine - an old diesel is different.
    Gazzz
