Thread: Disengaging 4WD in a Series 3.
    Oct 2006
    Samford, Brisbane
    I have finally got my 109" ute registered and on the road. It took me 18mths to do it, so thankyou everbody for all your help.
    Since driving, I have noticed that the 4wd system is alwayed engaged. I have put it in low range then in high range, but it still doesn't disengage. The yellow knob does move but I haven't seen what happens under the landy.
    Has anybody got any ideas?
    to engage 4wd hi push the yellow knob down.
    to disegnage grab the red low range lever and yank it back while the vehicle is only just moving.. the yellow knob should pop up. push the red lever forwards and your back in 2wd
    low 4 is just pulling the red lever back 2 "notches" and disengaging is just pushing it forwards
    usually 1 of 3 things has happened if the yellow knob doesnt pop up.
    1. its out of adjustment, theres a nut under the yellow knob that pushes down on a spring inside the cab. Wind that down. Dont wind the yellow knob down you'll put the rod through the top of the knob. Ive also seen them without the spring in which case 4 hi will not disengage as the weight of the linkage is enough to make it fall back into the 4 hi position
    2. too much mud and crud in the linkages on the front of the foot of the tcase, clean it up...
    3. internal siezure of the mechanism. sublte use of the knock ometer with very light oil in the tcase can work and if it does great, if not its time to strip the foot off.
    Try this.. to determine which you have pull up gently on the yellow knob while you pull back on the red lever. have someone underneath watch for the movement of the linkages.
    that is of course unless you have a stage 1 or conversion that gives you full time 4wd in which case, yes your ment to have 4wd all the time....
    Wheelers Hill, Melbourne
    How do you know you are in 4wd?
    On bitumen is the steering difficult, slow accellerating & poor top speed also squealing tyres( & alarming tyre wear) ?
    If not then then the problem will be you cant get 4wd.
    Otherwise what Blknight says, plus one other thing is the return spring may have wound itself down thru the hole it sits on, so get a suitable washer
    Melrose SA
    This description sounds like a Series in perfect condition lol
    I meant really slow
    Kippa Ring
    Similar thing happened to me when I did the rebuilt on my series 3. Had been off the road for a while so front output selector shafts had seized. Just take the front housing cover off, get some penetrating oil in there and try working them free. I think I still have a s3 workshop manual somewhere so let me know and i can scan the relevant pages and send them to you. Once you see the diagrams of how it all works it will make sense.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    Oct 2006
    Samford, Brisbane
    Thanks everbody, I knew the 4wd was on because when I was at the tip the front tyres were flicking mud and the rear was slipping. Also when I engaged the front hubs I had drive.
    But thanks for the help BLK night you were on the money. The spring wasn't lifting the leaver high enough. So a little oil a new nut and a washer (to stop the spring going down the holder (thanks DeeJay).All is good.
    Yes it had a very bad turning lock the top speed was about 80 k a hour but the tyres are good. Haven't taken her out for a long drive yet. but I have the fun tonight.
    Thanks everybody.
