Results 1 to 10 of 19
Thread: Disco Series 2 CAT Battery
    North West Tasmania
    HI All,
    can some one advise the part number and ho much of the CAT battery that fits into a series 2 Discovery?
    I think mine is on the way out. The indicator is still blue after driving for a while but after 2 weeks with these cold temps unused went to start and she was quite flat. Had to jump start off my second battery.
    McDisco Guest
    Piddler
    My brother in law had to replace a battery while we were over in Tassie. We asked the dealer in Launceston and they referred us to a battery place in the industrial area. He picked up a Full River battery (same size as the factory batter) with good CA for around $200 I think. Fitted it in about 10 minutes.
    Angus
    May 2003
    On The Road
    do you mean CAT as in catterpiller?
    as long as whatever you choose is calcium/calcium
    Yes they are Calcium 175-4370 is what I have in my D2a(http://www.cat.com/cda/files/192183/7/PEHJ0073.pdf)
    North West Tasmania
    Thanks DM_TD5,
    does that fit straight in the standard position without changing anything?
    Piddler
    Yep, you may need to trim a bit of lead of the poles - the battery comes with studs and the lead poles just screw over them (about another $2).
    North West Tasmania
    Hi DM_TD5,
    is there any reason I Should not go for the next size up battery and get the 1000 CCA version?
    I don't know much about them but thought for the same size frame might give me a bit more juice?
    Thanks Heaps for the PDF its great.
    Williams West Aust
    Hi Piddler
    This is the biggest PYSICAL SIZE that you will get in with no mods
    Unsure without looking at the CAT website if the bigger CCA batteries are bigger in size.
    This one is taller wider and deeper than the standard size,mine is only a 750CCA,but it was freemdid 3 years in a grader and now 2 years in my Disco.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    The one I have is the 825CCA which is bigger than yours. The 1000's the same size so no problems there. I couldn't get one without waiting so I took the 825 at the time.
    May 2003
    On The Road
    I wonder what the difference in price is,,,
