I replaced mine with the steel dowels over a year ago because the head gasket started to leak was allright only played up when I put the boot in and made it work,about six months early to the gasket leaking it blew a small coolant hose behind the turbo, it got hot and after that I fitted the black box water/temp warning alarm.
alot of people have fitted low water alarms to their engines and is a good idea also if you do not have a problem do not touch it may never give you grief and it is a labour intensive job and if you paid someone to do it it would cost alot more than $1200 to do.
Do a search on the head gasket and here is a link to my post on the head gasket I did a cost break down on the parts
http://www.aulro.com/afvb/showthread...ead+gasket+td5
disco seriesII mods so far:-bullbar,hyd winch,
detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
In the event of nuclear war,Disregard this message
