Results 1 to 10 of 16
Thread: Does any body know of a good gas fitter
    Jun 2007
    Minchinbury NSW
    I was thinking of taking up the opportunity of the $2000 cash back that the government has going, except rumor has it that gas fitters have doubled up there prices since the rebate
    How abrasive is LPG on D2 V8 any way
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    a location in your profile would help :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2007
    I've got mine booked in for the LPG conversion at Green Light Car Care in Thornleigh. From what I have read on AULRO here they seem to know and like Landrovers.
    I went to see them a few weeks back and they seemed like nice enough people too - I'm just waiting on them to get back to me with the installation date cos there is a bit of a queue and a shortage of kits.
    I'm getting mine fitted for $2840 (or summat like that) so once I have my $2000 cheque it'll be a princely sum
    However, since you have a Series 2 Disco you will need to get the more up to date (and consequently more expensive) gas injector system which from what I remember will be nearer the $4000 mark.
    2012 Discovery 4 SDV6 HSE
    2003 Discovery 2 TD5
    2003 Defender Xtreme
    1997 Discovery V8i
    Jun 2007
    Minchinbury NSW
    Quote Originally Posted by sam_d View Post
    Thanks Sam ill give them a call
    KLR Automotive/Diesel Gas Technologies in Penrith (Kingswood), NSW. They are a Land Rover specialist.
    RoverNit we don't know where you live so it's a bit hard. I guess NSW seeing as you are gunna call Thornleigh.
    As Incisor says - Update your profile.
    Ron
    Jun 2007
    Minchinbury NSW
    Ron
    I just did sorry should have done it a while ago took a bit to find kingswood sounds good
    Quote Originally Posted by ROVERNIT View Post
    Tel (02) 4721-3675
    Ron
    ACT
    Although they're in Vic, it may be worthwhile calling Deacon Auto (www.deaconauto.com.au) to get some advice and prices (don't tell them you're in Sydney) - they specialise in LPG fitment to Land Rovers. LPGas1 are also in Vic and are one of the most professional and high turnover LPG mobs in Oz, so also worth getting some advice from.
    Definitely go injected gas - you will lose less power (some claim you actually gain power) and won't have problems with blown airboxes and airflow meters... If you don't have injected, your ignition system will have to be absolutely spot-on at all times to avoid backfiring, and this can be difficult to maintain...
    Kyabram, VIC 3620
    Make sure you get it done at a proper place. With the D2 you cannot use the old system on injecting vapourised gas into the air intake like most cars
    The D2 you have to have the LPG direct injected (via injectors) into the cylinders - and it's a tad more complicated and obviously a tad more expensive.
    I believe that the pucker installation also includes a 2nd ECU to control the timing advance - which needs to be different to running on petrol - amongst other things it prevents backfiring - which you can get if the timing advance is either set to one fuel - or best of both (average) setting.
    Jul 2007
    SA
    Quote Originally Posted by ladas View Post
    Make sure you get it done at a proper place. With the D2 you cannot use the old system on injecting vapourised gas into the air intake like most cars .
    I hope this isn't a dumb question but why can't you use the vapourised gas system on a D2 (Not that I own one)?
    chosen
