Results 1 to 10 of 11
Thread: Dirty gearbox oil after 10000ks.
    Bundaberg Qld.
    I am not sure if there is a problem with the gearbox so I though i would ask.
    Was checking the gearbox oil level last as part of my 10000 ks service and found it had about 300ml extra, however the oil that came out was black, like used petrol engine oil (not pitch black like diesel oil). Which is not right as the oil is only 10000ks old. I have only owned the vehicle for 10000ks and put all new oil in when i got it. The oil I put in it was Penrite 15W-40 diesel oil. I had it so i used it. So what i wondered is, is something wrong in there making it black (it drives fine doesn't make any unusual noise), or has the diesel oil clean out all the gunge from its previous life? It is a Lt95 in a 84 120. Has 216000ks.
    I am going to replace the oil so will look for metal bits. Am thinking of replaceing it with a gear oil. Is this gear box affected by the EP agents?
    Thanks in advance.
    WR.
    84' 120" ute - 3.9 isuzu.
    if you changed the oil and put a fresh lighter weight oil that what was in it in it then id say that the oil youve just put in has cleaned up all the gunk and lifted the stuff that has settled on the bottom of the box which is what youve seen...
    This might last for 2 or 3 changes and is nothing to panic about unless you have metal bits in the filter or hanging onto the drain plug.
    Quote Originally Posted by wovenrovings View Post
    ...The oil I put in it was Penrite 15W-40 diesel oil. I had it so i used it. ... WR.
    have you put motor oil in the gearbox?
    NSW far north coast
    Quote Originally Posted by Michael2 View Post
    yep, that was the specified lube back then. Downside is It tends to shear pretty quickly and isn't the best for synchro performance.
    Christchurch NZ
    diesel engine oil is full of detergents and additives to keep all the crap in suspension. you have just cleaned the insides of the gearbox. some times this can clean away crap from around the seals and cause leaks, prob better with a less detergent engine oil or synthetic.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Christchurch NZ
    DONT USE GEAR OIL!!!!!! It can shear the teeth off the oil pump!
    you can use gear oil, you just have to make sure its the right type of gear oil and not the 80/90 type of stuff your thinking about.....
    Right off the top of my head AP5 is just marginally more viscous(thats the bit im guessing about) than ATF dexron III and has a better pressure loading characteristics (pressure that it takes to disperse the film it leaves) than dexron III..
    Christchurch NZ
    correct!
    Is AP5 not the stuff that eats brass? Or is that GL5?
    NSW far north coast
    xW-40 engine oils usually fall right at 14.5 cSt @ 100*C, which is what 75w-90 manual trans oils like Castrol Multitrax and Syntrax, and Redline MT90 also sit at.
    VMX-M and Syntrans are around 12cSt, and VMX-80 is approximately 10.5 cSt @ 100*C, which is in the range of an xW-30 engine oil.
    Quote Originally Posted by jimbo110 View Post
    correct!
    your thinking GL5 Ap 5 is the new breed of auto fluid.
