Hi Mandy,
Advice from a non-technical person:
The only modification I know of to significantly cut fuel costs is to get gas installed. The single carb conversions are usually for Holleys which have their own problems, but big increases in fuel economy I haven't heard of. Even the EFI versions are fairly thirsty.
On the plus side, you're in WA so you get a State and a Commonwealth gas subsidy.
There's no point changing the carbs if you get gas - the conversion of the dual carbs is pretty common.
Manual gearbox - I haven't done or seen an auto-to-manual conversion but as the auto is cut into the manual box, I would expect it would be reasonably straightforward. I would think the bellhousing would be required but otherwise pretty straightforward. But someone here will have done the conversion one way or the other, so you should get more specific advice soon
Steve
Steve
2003 Discovery 2a
In better care:
1992 Defender
1963 Series IIa Ambulance
1977 Series III Ex-Army
1988 County V8
1981 V8 Series 3 "Stage 1"
REMLR No. 215
