Results 1 to 9 of 9
Thread: Advice needed.
    Ystervark Guest
    Advice needed for 2lt Freelander.
    My wifes '99 2lt diesel freelander will not go into gear. I sent it in for repairs to a recomended Land Rover dealer in NSW two weeks ago. They seem to be lost to what the problem might be. The transfer case was replaced two years ago.
    Adelaide - Torrens Park
    More details?
    Manual, auto, etc.
    Bundaberg Qld.
    Have they checked for little rocks in the gear linkage/selector somewhere?
    84' 120" ute - 3.9 isuzu.
    Ystervark Guest
    Its a manual.
    Ystervark Guest
    I am not sure what they have checked, at this stage they are not giving me any info.
    Possibly the clutch hydraulics. Not sure about the diesels, but the 1.8 petrols have a sealed hydraulic system. To replace, it comes complete filled with fluid.
    SYDNEY -in the shire.....
    a quick test for the clutch is to start the car........press the clutch.......
    wait a couple of seconds.......then slowly select reverse........
    if you feel or hear it crunching instead of going into gear smoothly.......then the clutch is not disengaging properly.......
    do this test then get back to us........we will go from there.......
    Quote Originally Posted by BigJon View Post
    Diesels are the same. Could be the hydraulics if nothing obvious with the linkages.
    If it is crunching when trying to go into gear it could be a binding spigot bush. On real hot days mine binds making it almost impossible to engage 1st or reverse. I haven't fixed it as it only happens in summer and the clutch will need replacing soon. On this car it could be binding all the time.
    Gazz
    Jimboomba, QLD
    An obvious test that you have probably already done ... Will it go into gear without the engine running? This will eliminate or confirm the clutch as the problem.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
