Results 1 to 10 of 16
Thread: Vehicle stands and trolley jacks
    Brisbane, north of the river
    G'day all,
    I need to get some bits and pieces to be able to happily work under my vehicle and I was wondering what weights I should be looking at?
    Supercheap have Vehicle stands on special at the moment and they can hold up to 1200kgs, I was wondering if they would suffice? Considering that one of them won't be holding the entire vehicle up at any one time....
    What size / weight for the trolley jacks? 1.3tonne? 2tonne?
    For reference, I am driving a '94 300tdi Defender and the most work I will be doing with them is changing tyres (I expect).
    From experience, I can say don't muck around getting a cheap trolley jack, get a descent workshop quality one.
    I've got a 2500kg Armstrong and 2 x 2000kg rachet stands (need 2 more though). The jack is great, nice long handle and a small one for when you need to posiiton it carefully. This cost me about $200 several years back and was well worth it.
    A couple of years back big W had a good name one de-badged and it was pretty good value. I bought mine from there and it's been fine.
    mcrover Guest
    I suggest you get a 2 post hoist if you want to lift the whole thing off the ground but if you dont want to then the Armstrong 2500kg trolley jacks are very good, I have one at work and I havnt had any problems.
    I always found when changing tyres that if you just lift one end at a time or 1 side at a time it doesnt take any longer than lifting the whole vehical and putting it on jack stands and if you were doing brakes I normally just lift that corner Im working on and jack stand that corner as it is much more stable on it wheels than on stands.
    The jack stands are rated at there maximum working load per stand unless stated other wise and then they are meant to say they must be used in pairs so if you have 2000kgs per stand and your using 4 of them then MWL is 8000kg but I wouldnt like to trust them with 8 tonne on them but a Defa should be ok.
    Quote Originally Posted by mcrover View Post
    Likewise, that's what I do. As a mater of fact, I've just done this today! Jack stands only get used fully when I need to work under the vehicle. I still push one under the axle when I change a tyre, just in case.
    Dalby
    Where do you buy good quality jack stands from?
    The auto shop ones always look cheap and not tall enough.
    mcrover Guest
    I actually built my tall ones myself but you can buy 400mm tall ratchet ones that raise to about 550mm (or taller, never measured) at any reputable auto retailer e.g. not autobarn.
    My tall ones I made are 350mmx350mm square on the base and stand 600mm high but are fixed and normally need to jack and block to get things up there.
    Redland Bay QLD
    I use 3500kg locking stands, as i feel that if something was to fall, ie stand slips off the diff and catches the body, a strong stand will hold and save your life. Its not an excuse to use them incorrectly, but i feel much happier being under a car that simply cannot get to me. And yes, a good jack will get you better working height, and get there quicker. I tend to work with the chassis about 400-500mm above the ground. Regardless of disco/freelander etc.
    SYDNEY -in the shire.....
    get a jack of 2.5 ton minimum..........
    and the strongest stands you can afford.........
    i jack the landies up under the diff...........they go up on an angle as the diff isnt in the centre..........
    but when i lower it down onto the stands........i just make sure the stands are pretty much the same height...........
    the stands are placed under the diff housing between the rotor and the radius arms......
    then you can do exactly the same for the rear........
    hey grizz' get the best you can afford.
    as your truck only weighs about two tons and you can only can jack one end at a time, buy something that can handle the total weight.
    why, because it will not be working at the top range of its capacity, therefore it will have plenty of capacity in reserve, and not fail as early as one that 'just does the job'.
    the 1200 kg stands should do the job ok, if used in a corner at a time, but i would go for a higher rating, just to be safe.
    in the case of the truck falling off the jack you should have enough strength for the stand to stop it hitting you lying under it.
    and don't lie under it until it's sitting on stands and rock solid.
    i always try to rock any vehicle off the stands before i remove the jack from under it, the jack is stronger than me, so if it passes the 'push off and rock it'test i feel it is safe for me to crawl under it - it's amazing how you grab some part of the vehicle to move yourself when under the thing, that is why i make sure i rock it before i get under it.
    Safe Travels
    harry
