Results 1 to 9 of 9
Thread: 1996 3.9 problem
    Warragul, Victoria
    1996 3.9 problem
    Recently picked up a cheap 96 Discotaxi for the Handbrake.
    Starts and runs beautifully 'till it warms up a bit then the problem starts.
    If I drive about 1 or 2 kilometers them pull up to give way at an intersection or roundabout (Its a Disco not a Volvo...), it idles fine but when I go to take off it coughs and dies.
    Restarting it is a cast iron bitch, how can a Fuel Injected motor flood?
    It reeks of fuel, and when cranking it verges on running but juuust not quite starts and runs. I've tried Aerostart, showed it a big hammer even pulled a box of matches out and swore at it but it won't go till its good and ready, then it will run fine all day.
    Is there a temp sensor or something that could be U/S?
    lokka Guest
    Sounds like a tempsensor or the cold start injector on the top drivers side of the plenim or try here http://www.britishv8.org/Articles/Rover-14CUX-EFI.htm
    G`day
    Could be the ecu coolant temperture sensor
    The one on the inlet that has a connector plug like an injector connection plug.
    If you put an ohm meter on it and it`s open circuit that`s the problem .
    If so a 170 Ohm resistor can be fitted after its warmed up , to get out of trouble short term .
    The throttle position sensor may be out of adjustment/range and could be a cause but the first place i`d try is the coolant sensor . ( not sender )
    If you find a cold start injector then you have more trouble .
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    my money is on the ignition module
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Adelaide Hills. South Australia
    ..........& that has been discussed here recently.
    A temporary "fix" or proof was to tip a bottle of cold water over it or hold a wet rag on it.
    Cools down, works ok again ............. that's it.
    Warragul, Victoria
    Quote Originally Posted by lokka View Post
    Pulled both the Temp Sensor and the Plenum Injector, cold start injector was covered in an oily sludge so I cleaned it off.
    I'll have to get a multimeter onto the Temp Sensor, I can't find mine so I'll do it at work tomorrow.
    After that its a process of elimination I guess..
    Thanks all for your help so far.
    Avoca Beach
    Cold Start injector? 96 Disco?
    That is your Stepper motor, which adjusts idle for load.
    I concur with ECU temp sensor, and TPS.
    and maybe coil and /or ignition module.
    Regards Philip A
    Warragul, Victoria
    Regards Philip A
    Lokka called it a cold start injector in his post, its actually the Bypass Air Valve
    The Ignition Module you refer to, is that the Pick up coil amplifier on the side if the Distributor?
    Avoca Beach
    Yes, I have never had one go but it is common and they seem to fail from heat. IE they go OK until the engine bay gets hot.
    I suggest you do an injection diagnostic, which was posted on the forum a couple of months ago, and should be found with a search.
    If the MAF fails , the car should still drive OK as it will be in "limp home".
    Its hard to be pedantic( or easy depending on who you are!) but my first thought is that he TPS is worn just off idle . But it should not cause flooding . Also this should cause a big "flat spot" if you are overriding down a hill then put your foot back on the accelerator.
    Regards Philip A
