Results 1 to 10 of 12
Thread: 200tdi oops!
    Mar 2007
    Living the dream!
    200tdi oops!
    have a bit of a sticky situation and would like to ask some advice
    theres this mate of mine right.....
    after replcaing the timing belt on a 200tdi (defender) somebody forgot to take out the timing pin from the injector pump and reassembled the timing cover....
    when the engine was turned over, it all turned pear shaped.
    so far diagnosis is a stuffed inner timing cover, some bent pushrods, a stuffed timing belt and one VERY red faced home mechaninc....
    im told the fuel pump spins, altho dont know if it is a "normal" spin or not
    what other sort of dammage can we expect?
    im not there at the moment, but will probably make the treck up to albury to help out with the repair effort wednesday
    Apr 2007
    Clifton Springs, Vic.
    Tell Tom I feel for him.......bugger
    There is an Isuzu motor and LT85 Gearbox for sale in the Market section.
    Mar 2007
    Living the dream!
    yeah a situation id rather avoid myself.
    he is already talking bout going down that line. worth trying to fix the 200tdi first tho
    he got quoted $4000 for a reco injector pump.... Yeah right!
    Oooh! Sounds like those pins need a big ribbon on them like the ones aircraft pitot covers etc., have
    Ron
    Adelaide - Torrens Park
    Ron
    We paint ours bright yellow.
    Mar 2007
    Living the dream!
    i use one that is too long for the timing cover to go back on.
    still, any idea how much dammage it may have done?
    Warburton, Victoria
    Valves should not be bent as the valve is 90 deg to the piston. it's a direct hit.
    Id get him to replace the pushrods and the cover then do it all again, but remove the timing pin....lol
    See if it fires up... if it does then its ok, if not then get the pump replaced...
    Thats what i would do, but others might not do the same.....
    Kingston, Tassie, OZ.
    I have an injector pump sitting in a box that I look at every now and then to remind me TO REMOVE THE TIMING PIN before turning the key...
    YES, I have broken one a long while back and it still haunts me...It broke the casting out at the front where the pin sits inside, and consequently the front seal and bearing were damaged, rendering the pump U/S.
    I would firstly talk to a diesel injection specialist, as a new Bosch VE pump body is only around $400.00. Including labour and seals and assembly set up etc it should top out at about $1100. max. This isn't such a bad thing as a 200Tdi is getting long in the tooth and could benefit from a pump freshen up anyway....
    (Sorry, just trying to be positive)
    Alternatively, I may have access to a SH unit if you are interested.
    JC
    I buy up any 200tdi engines I find, most are damaged by guys doing off road stuff and get water sucked in. Last one I got was about 250AUD complete with all accys. The turbo is worth that on its own.
    Maybe you could pick up a duff 200tdi engine and swap the parts you need. Rebuilding an injector pump is no big deal, just be very careful and work with clean clean clean tools and work area. I will see if I can dig out a series of pics on rebuilding a Bosch pump. Its not impossible to do, again be careful, take notes and keep clean clean clean with everything.
    I have yet to take a pump off a duff engine and find its buggered. Bent conronds and push rods are common with cam belt breakages and hydraulic lock. With your unfortunate engine, it will be cheaper to buy a complete duff engine for parts. Forget rebuilt pumps unless you are really stuck, they are $$$. To make you feel better, be thankful it wasnt a 300tdi pump you had, otherwise you would be heading to the dealer with condom and jar of vaseline in hand
    Mar 2007
    Living the dream!
    thanks all for your input
    i havnt seen the engine as yet so i am going off 2nd hand info
    from the sounds of things JC may have it right as far as the injector pump goes. are there any simple tests that you can do to see if the injector pump is ok?
    also, what is the likelyhood of anything else being dammaged in the engine, tappet guides, valve heads????
    from what im told the engine didnt fire, just a really loud crack when the ignition was turned
    i think ron had it right with the ribbon on the timing pin, and attach the key to the other end of the ribbon
