Thread: TPS 3.9 Disco
    Island
    TPS 3.9 Disco
    Howdy, can a guru please tell me the voltage readings for my TPS in a hotwire 3.9 D1?
    I've scoured & found a thread on a RRC which should be the same system?
    http://www.aulro.com/afvb/showthread...&highlight=tps
    Here JC says 320mV - same for mine?
    Adelaide Hills. South Australia
    Island
    thanks 4Bee, now I remember somone posting that link before.
    Kingston, Tassie, OZ.
    OldZook,
    I would suggest that if you set your TPS to .85v or through to 5.3V you will have some problems!
    320mV is the factory spec for all hotwire 14CUX systems.
    JC
    Island
    big thanks JC, thought I'd read that somewhere once, was trying to cross check it but trawling thru all these posts etc takes it out of you.
    0.85 sounded a bit off and 5.3 might be a bit elusive...
    Dan
