Thread: Vogue SE Electric seat queries
    ibest Guest
    I have a recently aquired 1991 Vogue SE which is to be modded to a weekend rock crawler and tourer and i already have the 300tdi auto disco from which will come the required motor/box/transfer case. The electrics must all go from under the seats for water protection so the seats will be swapped for manual units.The ABS will be swapped for normal brakes (all engineered) and the ECU of course will go. Question? Which of the relays, fuses and electric gizmos under the seats relate to the seats? The harnesses all seem to blend together and the maze of wiring is daunting. I can handle all the old fashioned wiring OK but a guide here as to what is what would be great as it could save a lot of time and frustration. Has anyone done this that could help?
    Anyone want electric leather seats as swap for manual velour jobs?
    Anyone want full Wabco ABS complete with computor as swap for Normal power assist system ?
    KevinM Guest
    Seats
    Maybe interested in a seat swap. What colour and condition are they in & where about are you located.
    Kev
    51jay Guest
    Get yourself the workshop manual...it's all in there....don't remember offhand whether it's in book 1 or 2
    ibest Guest
    Quote Originally Posted by KevinM View Post
    Kev
    Hi Kevin, The seats are a cream colour , the left one is beaut but the drivers one has a split at the inside seam of the outer pad (if that makes sence) about 150mm long.The electrics on the left are fine,the drivers side the switch for recline goes back but wont bring the seat forward again . this is overcome by using a memory position to go forward and then adjust back,so the motor and mechanicals are good but a glitch with the switch or a connection i guess . I will have a look at that very soon. the rest of the drivers side functions are all good. i am located in Sydney near Hornsby. If this is of interest let me know the same stuff about yours.
    Thanks for the query, Ian
    May 2002
    Sydney, Australia
    G'day Besty!!!
    Was the Haynes book any use? Give me a shout if you need the other info
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
