Results 1 to 4 of 4
Thread: Landy Painting
    Landy Painting
    Hello Folks,
    I am just finishing the removal of the old paint from Series 3 Ute cab rear section, Before i go to the Auto paint shop and get some paint matched for Yellow Pezza, i should probably work out exactly what I am going to get. So, what I would like to know is,
    What is the best thing to prime Aluminium with prior to painting?
    and, What can I use to inhibit corrosion in aluminim, for the areas i am not painting?
    I know of a few products in the world of aviation for aluminium treatment, but they usualy of the same $$$ price tag as the rest of the industry!
    Any Ideas
    Cheers, Paul
    Etch primer is what you need for painting aluminium.
    Aluminium will not corrode if protected from moisture or protected from contact with other metals, so a sealing coat to penetrate any joints and keep out water is indicated.
    When painting mine I disassembled the body so there were no joints that did not get painted on both surfaces.
    Hope this helped
    Hope this helped
    Yep, that is pretty much what I am doing to all the ute pannels, pulling apart as much as i can, particularly Aluminium to Steel joins, and cleaning up dents as i go.
    I will hit every thing with the etch primer tommorow!
    Thanks JD
    Paul
    Don't forget that only a thin coat is required with etch primer.
    Ron (still on a 1 litre tin bought many, many years ago)
