As Michael says, but check (either underneath or by removing middle seat panel) that there are no problems with the linkage. I have encountered a broken clevis and a broken threaded rod, and also the pivot that the bell crank turns on either loose or its bracket broken. It is possible yhe bell crank is seized on its shaft - it has a grease nipple but often gets missed when servicing.
A further possibility is the expander rusted up, although I have never struck this.
Properly adjusted, linkage OK, and oil free the handbrake is extremely effective, although it will overheat and wear rapidly if used for stopping rather than holding.
