23rd July 2007, 10:29 PM
lightforce for arb bullbar
Hi guys
I have a set of 240mm 240 blitz lightforce round driving lights
i will be purchasing an Arb deluxe winch bullbar for my disco 2 in a
couple of weeks and was wondering if there would be enough room
between the top and bottom bar to mount them on the driving light
tabs provided or would i be better off with a TJM bar instead.
thanking you
phataz
23rd July 2007, 10:32 PM
Don't know which style but mine is an ARB. It even has spacers on the tabs fo the spots and they fit.
24th July 2007, 03:29 PM
Spacers...
Yep I had to make some spacers for mine to lift them or the light housing hit the lower bar and it tilted up. Two bits of about 5 or ten mm flat bar about 40x40 from memory, hole drilled in the middle to suit the light mount stud.
Out of interest, I "nudged" a lamp post hard enough to shake it, and the blitz, which is proud of the bar, only suffered a broken filter and a small crack on the thin rim. It actually bent the ARB metal tab on the bumper without breaking off!
