3rd August 2007, 11:20 AM
Long Range petrol Tank LPG
Anyone here fitted a Long range tank AFTER they had a manifold tank LPG tank installed in the back of their DII.
I have talked to a few 4x4 shop installers, they have **** for brains when it comes to LRs.
The trouble is that they need access to the panel under the rear floor. The LPG Guys removed the fuel tank to bolt the LPG tank down. I think they will need to unbolt the LPG tank to install the long range tank and there's the Problem....
There is always a way. Sugs!
3rd August 2007, 11:38 AM
When I replaced my fuel pump in my V8 D1 I was wondering how much harder it would be if I had a manifold tank.
The RAVE manual says you have to access the hatch to disconnect the fuel lines before dropping the tank.
Maybe th LPG installer modded your fuel lines so as to be able to have enough length to lower the fuel tank without accessing the cover?
