Thread: Nuts 'n' bolts...
    Apr 2007
    Nuts 'n' bolts...
    Can anyone suggest where I might be able to get High Tensile nuts and bolts from?
    I still don't know Sydney too well and my searches on the net only come up with fastener wholesale and manufactures.
    Bunnings only appear to sell mild steel bolts. Where else is there to try?
    2012 Discovery 4 SDV6 HSE
    2003 Discovery 2 TD5
    2003 Defender Xtreme
    1997 Discovery V8i
    I'm sure there are loads of others, I usually head to Marrickville
    http://yellowpages.com.au/search/pos...rrickville+NSW
    Tower Fasteners Pty Ltd
    34D Fitzroy St Marrickville NSW 2204
    ph: (02) 9519 3233
    I think it's Tower that I usually go to. There's another place over in Alexandria, too. Could be these guys.
    Bremick Pty Ltd
    F1/ 62 Maddox St Alexandria NSW 2015
    ph: (02) 8332 1500
    Simon
    Apr 2007
    South Australia
    Quote Originally Posted by sam_d View Post
    Hmmm all the bunnings here sell them, the black one's? I am assuming they are HT as they were sold me as HT nuts n bolts?
    Are the bunnings ones no good?
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    99.87 MB
    Lee Bros next to the jail at Parramatta are excellent. They sell any nut and bolt that you could possibly think of - actually thats mainly what they sell. I'm pretty sure they used to be called the nut house.
    Slunnie
    Adelaide Hills. South Australia
    HT bolts/screws have a code stamping on the head.
    I can't recall what it is now but it identifies HT.
    eg. Grade 8.8 . May also have the Spec #, eg. A.S.1110
    There are also Black Hex. Head in Black Steel. Commercial Grade.
    *** Don't use these where HT is recommended.
    Mansfield, Victroria
    Fred Tapping at Ingleburn would be my choice.
    Mick
    It would help if we knew where in Sydney you live, Sam. Put it in your profile.
    Ron
    Yass NSW
    I know our mitre 10 stocks them. They are a rural hardware store though so are used to the farmers coming in wanting bit's and pieces. I normally take a sample with me and tell them what I want it for. They happily go through the range to find the right one.
    Rydalmere, Sydney
    Bolts aint just bolts!
    I went to Lee Bros on Friday last week and was a little dissapointed with the lack of range and advice! have been going there for years and have been excellent in the past.
    Tower in Marrickville are good as are Coventry fasteners who have several places and agents.
    HT is not as simple as High tensile please. Also tensile is not the same as shear strength.
    Several systems and grades and markings. Some times a grade 5 is better than 8 or 12 as the "stronger" ones get extremely brittle.
    Also Hex head bolts are not as strong as Socket head cap screws. and as said above the shank is much stronger than the threaded bit. Then you get coatings. Zinc can make the bolts even more brittle! Some times painting the black ones is the best.
    And often the shop will impart knowledge and specifications but you need an engineer to tell you which one is best!
    james
    Douglas Park, NSW
    Quote Originally Posted by zwitter View Post
    One of the good guys who used to work there is in the LROC (Sydney). It's a shame he retired.
    There have a couple of new staff members but the older ones are usually very helpfull.
