Results 1 to 10 of 13
Thread: Urgent advice please - checking ATF on P38a
    Wilbur Guest
    Greetings All,
    Hope some one can give me some quick advice please. How do I check the automatic transmission fluid level on a 2001 P38A?
    It 'declined' to move a day or so back when parked nose-down and put in gear, but after a few 'reverse-forward-reverse' cycles came good, has gone fine since.
    I head off on 1,000k trip to civilisation later this week, but am afraid I could be in trouble if the fluid IS low.
    I can't see a dipstick or a level plug anywhere. The front of the bellhousing is very slightly oil-damp.
    Any advice or other suggestions very gratefully received.
    Thanks,
    Paul
    Quote Originally Posted by Wilbur View Post
    Greetings All,
    Thanks,
    Paul
    i know this might sound like a stupid answer but dont you have a manual that came with the car???
    Wilbur Guest
    Yes, but it has more information about the use of the digital bum-wiper and Satnav than things like mechanical maintenance... the way of the future I guess.
    Paul
    ummm correct me If im wrong but Isnt the p38 one of those ones fitted with the auto that your not ment to check the oil level on, its ment to be done by the greaser come servicing time?
    99.87 MB
    Warm it up, cycle the gearstick through all of the gears a few times and then you check the level through the fill hole. Weird I know.
    Slunnie
    Pre-99 model P38A do have a real dipstick, the later ones don't.
    See RAVE for the correct procedures.
    Ron
    Ron
    Its no fun taking the shots when you make them that easy Ron..... :P
    May 2003
    On The Road
    although thats what I ment by done by the greaser at servicing time.....
    but IMHO that procedure as describe could be wrong (havent read the relevent rave section in full yet) but doing that would leave the TX over full which has the potential to be bad.
    I would think that you would check it cold before starting it when most of the oil would be in the sump and not held up in the TC and the shifting gear.
    Set RR at standard height. Put solid chocks at front wheels and behind rear wheels. Else put RR on 4 jack stands if you need more clearance to crawl under the vehicle.
    While AT is COLD remove filler plug and check level...should be just able to dribble over the bottom edge.
    Get someone (you trust!) to ensure handbrake is firmly applied and start the engine and idle it while you slowly add additional fluid until it just begins to dribble again.
    Get them to go through the gears twice, a couple of seconds in each gear, then back to neutral while idling. Add more oil if necessary until it is just dribbling over the bottom edge of the filler hole. Replace the filler plug. turn off engine. Do Not overfill -this is very important
    It's a messy job. Safety is paramount!
    Good luck with it!
    Hoges
